BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
Vtl - is it actually a “rack?” Do the separate units at wheels talk to each other? Does the car have to be perfectly level, with no bumps to mess with wheel level and corner weighting?
I should just look it up.
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
BlackBart wrote: 03 Dec 2023, 16:34 Vtl - is it actually a “rack?” Do the separate units at wheels talk to each other? Does the car have to be perfectly level, with no bumps to mess with wheel level and corner weighting?
Well, sort of. The bigger thing on rear wheel does have a couple of lasers. On points to the scale of similar thing on another rear wheel, so you would know a toe-in/out. Another one points to the scale on the front wheel, so you would know thrust vector.
In my experience a typical concrete or asphalt driveway is more than enough for DIY alignment. Garage floor for sure.
vtl
Post by vtl »
volvolugnut wrote: 03 Dec 2023, 10:01 I looked for the TrackAce to purchase in US, but did not find it. I can purchase from UK source, but did not want the import pain.
I guess, I don't need mine anymore...
Year and Model: 2001 V70
Been thanked: 1000 times
Post by volvolugnut »
vtl wrote: 03 Dec 2023, 16:45
Want to sell it?
dono
Year and Model: 04 V70&XC70 2.5T AWD
Has thanked: 42 times
Been thanked: 6 times
Post by dono »
Front Struts on the XC70 used Sachs/Volvo parts from FCP (when these are worn Ill maybe take advantage of parts for life and get a new set free from FCP) as I decided the IPD springs were not for sure as good as the original Volvos. So took my time with the spring compressor. Forgot to order the wheel speed sensor plastic holders - they always break so I just gorilla taped & lightly glued to strut. Ill do rear when it stops raining tomorrow then alignment on Tues. The ones I pulled were pretty shot - I think they were 19 year old originals with 130k mi.
2004 V70 AWD Wagon 2.5L L5 DOHC 20V TURBO 268k mi :D
2004 XC70 AWD Wagon 2.5L L5 DOHC 20V TURBO 155k mi :D
1999 Mercedes e320 4Matic 238k mi :D
2008 Toyota Avalon XL 165k mi (meh)
vtl
Post by vtl »
volvolugnut wrote: 03 Dec 2023, 17:53 Want to sell it?
Yep. Let me wait for a large enough Amazon box... ;) Shouldn't take long.
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
The cable tie clips to hold my harness to the fan cowl were all either missing or burst so I ordered some non Volvo ones from eBay and fitted them today, another job ticked off the list
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
P80GLT wrote: 04 Dec 2023, 08:23 The cable tie clips to hold my harness to the fan cowl were all either missing or burst so I ordered some non Volvo ones from eBay and fitted them today, another job ticked off the list
Very cool. I still live mostly in the past where you bought things from the OEM, the local parts store, or it was not available.
I need to be reminded from time to time that Amazon has many things if you just look.
Blacklab467
Year and Model: 2007 xc 70
Been thanked: 262 times
Post by Blacklab467 »
Good to know that they're available from Amazon, I've been hoarding them from vehicles in the auto wreckers but they're often a little "crispy" after 20 years!
2003 XC 70 (sold)
P80GLT
Post by P80GLT »
I had a bit of an epiphany this afternoon after I fitted the cable tie clips!!!
Although not impossible to release the cable ties, the location of them makes it extremely difficult to get to the tab with a tiny screwdriver to release the tooth that allows it to open, therefore cutting it is the quickest/easiest way when required.
When I built my garage back in 2008 I used cable tie clips for the lighting cables, drill a hole in the joist, hammer the clip in, put on a cable tie in and the job's a good-un.
I decided to take a look at the huge bag of clips I had today and although I've not tried on the car yet I'm sure it will go straight into the fan cowling allowing me to use a standard cable tie that can easily be disposed of and a fresh one fitted as required. Will update once I have tried it out
Originally 42mm cut to 19.5mm
2010 XC90 SE...SOLD
2005 V70 2.5T SE
