Cold Concrete & Your Back
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
I have a 2' x 4' sheet of this left over from some work. It saved your back and side from the damp cold concrete in winter and summer. When you're young it's not a problem but overtime :( . This does snap if the surface is not flat though the thicker ones are hardier. I put this on top or the bottom of a moving blanket. Helps with the knees also. The 2" is ideal and a worthwhile expense.
https://www.lowes.com/pd/GreenGuard-Gre ... 5001939653
Board Insulation.png (695.43 KiB) Viewed 271 times
BlackBart
Has thanked: 927 times
Been thanked: 885 times
Post by BlackBart »
If I used that I’d hit my nose on the muffler. Maybe taller jackstands...
Actually this is a good idea. I have sometimes used a big sheet of cardboard or those surplus hospital surgical tarps.
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 131 times
Post by 454cid »
I have a piece of very thick carpet that I use every once in a while, for cleaner jobs. Normally, I use a piece of cheap linoleum/vinyl flooring. It's nice because I can easily clean it. It's not nice because it always wants to stay rolled up. I have to weight it down with rocks, and it's also starting to have pieces fall off. Once in a while, I'll use a cardboard box.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 1506 times
Been thanked: 3822 times
With so much moving going on , I have moving blankets everywhere, which are great for car work.
I’m usually using them to keep cool as much as warm, but I’m a polar bear. Long Island is great for car work in winter, a nice 40-50F
Lately , though, my car problems have involved putting gas in the tank.
Year and Model: 2001 V70
Has thanked: 928 times
Been thanked: 1002 times
Post by volvolugnut »
The insulation panel is a great upgrade from my typical cardboard creeper.
volvolugnut wrote: 06 Dec 2023, 08:09 The insulation panel is a great upgrade from my typical cardboard creeper.
I like the cardboard creepers that come with free pizza!
I seem to have a lifetime cardboard creeper supply deal with Amazon. My wife may have arranged that.
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 337 times
Post by Chuck W »
I keep a supply of large area cardboard onhand at all times. I also have 3 pieces of some high-density foam sheets that I acquired from some packaging that I use as cushioning or mats, depending on what I'm doing. I've got a lot of miles and abuse on my 55-year-old knees.
Somewhere I have a foam kneeling pad that helps for knees. I also used it for a roofing job as a butt pad to cushion my hip while sitting on the roof.
volvolugnut.
MoVolvos
Post by MoVolvos »
Chuck W wrote: 07 Dec 2023, 07:12 I keep a supply of large area cardboard onhand at all times. I also have 3 pieces of some high-density foam sheets that I acquired from some packaging that I use as cushioning or mats, depending on what I'm doing. I've got a lot of miles and abuse on my 55-year-old knees.
My supply comes from Costco's detergent section. The ones that are layered between the products for stability during shipping are pallet sized 40" X 48". I just fold them and tuck them under the shopping cart and hopefully they don't slide out once or twice during my Costco run. Knees and lower back for me.
