SOURDOUGHJIM
Year and Model: 2004 V70 2.4
Has thanked: 53 times
Been thanked: 27 times
Post by SOURDOUGHJIM »
Oil change. Auto trans dump and fill. It only took 3 qt, 8 oz. Anyway, the transmission seems smoother now. Could be my imagination.
ljsommar1
Year and Model: 2002V70
Been thanked: 8 times
Post by ljsommar1 »
I added one quart of 0W-40 oil to my 2002 V70 to bring level back up. Odometer is at 242250, I had changed @ 240K miles. So that works out to burning 1 quart around every 2250 miles, which I would think is pretty good for a 21 year old car with that many miles. What do the experts say.
Is there anything I can do to reduce this, valve guide seals perhaps or should I be happy with that. I see no evidence of any leaks.
Thanks for weighing in.
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 603 times
Post by vtl »
0.5q per kmile is not great, but a commonality with these engines.
SOURDOUGHJIM
ljsommar1 wrote: 12 Dec 2023, 16:23 I added one quart of 0W-40 oil to my 2002 V70 to bring level back up. Odometer is at 242250, I had changed @ 240K miles. So that works out to burning 1 quart around every 2250 miles, which I would think is pretty good for a 21 year old car with that many miles. What do the experts say.
I just happened upon this video on the 0W-40 Mobil product. I thought it interesting that their info on direct injected engines showed this oil performed badly. My owners manual recommends 5W-30 for my 2004.
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
Yes, one quart of Swepco at time of oil change with a 5W-40 instead 0W-40 will not only lessen oil consumption but will also make the car quieter and buttery smooth. Have used this on several cars including a 98 S70 T5 with 240K.
306 Supreme Formula Engine Oil 15w40
(www.amazon.com/306-Supreme-Formula-Engi ... B00K0TA5BA)
MoVolvos
Post by MoVolvos »
SOURDOUGHJIM wrote: 13 Dec 2023, 04:04
I started using M1 in the mid 90's from the recommendation of my Service Manager at Pepboys. Back then it took sometime for info about M1 to get around as you had to read it or from people who worked on cars. Lost 3 head gaskets over a period of time and finally figured out it was the M1 Synthetic. After years of not using it saw the 0W-40 on sale at Costco so tried it. None of cars liked it and the lower end groaned badly during passing.
When discussing problems with head gasket leaks from synthetics you'll find M1 in the discussion.
vtl
Post by vtl »
I don't like it at all. Second oil change (OCI 2300 miles) after engine rebuild (4700 miles), when oil sump was hot tanked, clean and shiny:
yanga001
Has thanked: 59 times
Been thanked: 110 times
Post by yanga001 »
vtl wrote: 13 Dec 2023, 11:35 I don't like it at all. Second oil change (OCI 2300 miles) after engine rebuild (4700 miles), when oil sump was hot tanked, clean and shiny:
Found mobile 1 synthetic was slightly louder in my partners car (old Acura with 320k km) than using penzoil ultra.
2008 S60 2.5T Auto (Sold)
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
Time to change over the plush carpet mats for my winter rubber mats/trays. Sadly the rubber mats/trays are no longer available but I managed to find these well used ones which required a lot of work to get them into the shape they are now
Mat Driver Side.jpeg (257.59 KiB) Viewed 427 times
Mat Passenger Side.jpeg (261.94 KiB) Viewed 427 times
Mats Rear.jpeg (256.94 KiB) Viewed 427 times
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
vtl
Post by vtl »
P80GLT wrote: 20 Dec 2023, 04:15 Time to change over the plush carpet mats for my winter rubber mats/trays. Sadly the rubber mats/trays are no longer available but I managed to find these well used ones which required a lot of work to get them into the shape they are now
That's fake photos! Too clean to be true! Likely AI-generated or something.
