Hello internet people,
I recently looked at a 1996 850 AWD and I am looking to buy it if the ADAC pre-purchase Check doesn't reveal any unexpected surprises.
The car is low KMs (114), drives really nice and I believe the body work will scrub up with some love and tender care.
However, when I was under the car poking around blindly with the phone camera I found a leak from somewhere. The car passed the PCV glove and dipstick test without issue so I am hoping it's not the dreaded RMS leak.
I have attached a video of said blind poking in the hope that it might give someone a clue. The bolts around the oil pan are very dirty but have read this is rarely the souce.
Based on the video does anyone have an idea where the leak might be coming from?
Thanks in advance
1996 850 AWD oil leak
Randomnamegenerator
- Year and Model: 1996,850 AWD
- Roger_850T
- Year and Model: 854T 1995
- Been thanked: 26 times
Not the rear main seal, that would come out of the weep hole between the oil pan/block and the transmission. I can’t tell if it’s turbo or not; if it is a turbo I would suspect the turbo oil return line, likely where the line drains into the oil pan.
Roger
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
05 XC90 V8 213k
- Has thanked: 1855 times
- Been thanked: 1714 times
+1 with Roger on this. Does not look like RMS. It is a turbo if it is an AWD, although as it is in Europe not sure if they got a non-turbo version.
Randomnamegenerator
Thank you for the quick reply. The car is turbo LPT model.
If it is the turbo return line it looks like a simple fix?
It is not easy on a FWD, but a devil to access on an AWD without a hoist as the angle gear makes access really challenging. I gave in and had a dealer do it for me.
- Has thanked: 1507 times
- Been thanked: 3825 times
On any turbo the tool needed for the M5 bolts on the drain tube is a ball headed hex driver bit to allow off axis torque
Light hand on these , like 15Nm or 10 ft lb
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 131 times
To my untrained eye, that doesn't look like much oil, to me. I'd probably clean it up with the pressure washer, and then not worry about it.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
