Parking brake cable rubbing on tire.
99TurboBrick
Year and Model: 1999 S70 T5 Manual
Has thanked: 35 times
Been thanked: 13 times
Post by 99TurboBrick »
This cable was replace by a Volvo mechanic less than 2 years and 3k miles ago. Recently I started hearing a scraping/thumping sound when I was backing out of my driveway. I had a look under the car and saw this. What would cause this? Wrong part? Improper installation?
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 336 times
Post by Chuck W »
It's supposed to be held tight to the rear arm with a cable holder, but they don't hold up too well for reuse.
I've used a couple long zip ties to retain the cables on my T5.
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
What size are the tires on the back?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1505 times
Been thanked: 3818 times
Someone broke the Torx bolt that holds the cable to the frame.
Zip zip zip goes the tie tie tie
99TurboBrick
misha wrote: 18 Dec 2023, 16:39 What size are the tires on the back?
205/55-16
Has thanked: 1848 times
Been thanked: 1710 times
Did the mechanic use a Volvo part? If not, then this is likely a Pro-Parts Sweden or other aftermarket part. I had this issue on one of my cars as the aftermarket part had been made wrongly. The distance between the mount forward of the rear wheel and the hub was too short. In my case the wheels would not even go back on!
It should not have seized or broken like this one appears to have done. As the guys have said, this should be well away from the rear of the tire and rim and mounted to the rear trailing arm. As suggested stout Zip-ties around the trailing arm or fitting the correct plastic mount held in place by a pop-rivet. I use a small washer on the rivet to spread the load as otherwise they tend to snap quickly. You could do both!
Oh, and my car had 195/65/15 tires and Volvo rims on it!
Good luck!
misha
Post by misha »
99TurboBrick wrote: 18 Dec 2023, 18:13
205/55-16
It's probably bad aftermarket parking cables.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
crlande
Year and Model: 240DL;850;S70
Been thanked: 36 times
Post by crlande »
Looks like you will be replacing cable as the sheath is now split. Then make sure it secured to trailing arm.
