Lesson learned (Ignition Coil Purchase)
Been thanked: 476 times
Re: Lesson learned (Ignition Coil Purchase)
Post by cn90 »
Stick to Bosch.
Or get the used Genuine coils from junk yard ($10/ea in my area). Test one by one (label them as "checked").
This way you know the used coil is ready to be used, if necessary.
Has thanked: 294 times
Been thanked: 767 times
I agree, I'd get Bosch not the IPD HD ones.
Used will likely work just fine to keep the car running but may not improve the smoothness like new will. I measured 10% improved mpg (!) with new Bosch coils on our 07 XC70, replaced preventively.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1254 times
Post by matthew1 »
erikv11 wrote: 31 Dec 2023, 09:55 I measured 10% improved mpg (!)
:shock: :shock: :shock:
Also -> Amazon link
Yes!
My wife was driving the same out-of-town workplace every week for a couple months. MPGs went from 21.something to 23.something with solely swapping the coils. Same gas station, same route, same driver, across a few full tanks of gas.
'06 S60 R, 197k
Krons
Has thanked: 193 times
Been thanked: 203 times
Post by Krons »
erikv11 wrote: 31 Dec 2023, 09:55 I measured 10% improved mpg (!) with new Bosch coils on our 07 XC70, replaced preventively.
Wow this is impressive. Been chasing a slight drop in mpg on my 08 and with 164k on the originals I may need to do coils.
abscate wrote: 09 Dec 2021, 05:33 For my vehicles that cruise 590 miles from home, warranty is useless. I’ve been stopped twice by coils going bad over 21 years, both of which were 100k miles plus Bosch or Volvo coils.
For my cruising cars, I replace them at 100k and then use the old ones in cars that don’t stray so far from home. Luckily I have 20 coils in circulation all of the same part number. I have also unloaded some for $10-15 or on the FDPP.
You should carry a spare used coil and spark plug in your tool kit if you have a coil on plug car.
This is great advice Abscate.
When I bought the kids 02 at 150k it had a slight misfire…at time I went cheap as I didn’t want to pour lots into it. At 40k with these (and Bosch plugs):
https://www.ebay.com/itm/252437228424
Likely will go Bosch this time.
08 C702.5T (sold)
The non-Swedes:
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Post by 02V70 »
You can get 5 of the bosch coils on rockauto for about $40 cheaper than other places like Fcpeuro. However, fcpeuro has free shipping and a lifetime warranty, so that might make it worth it.
2002 v70 X/C 288k miles
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
erikv11 wrote: 31 Dec 2023, 13:32 Yes!
I installed a set of Iridium plugs in our 03 Odyssey 90K miles ago. When first installed the van was silent and had improved power. Had two other friends installed in their Odysseys of the same vintage. I know for sure the mileage at one time was extremely good. Time to install another set as mileage hasn't been high for a couple years after we moved. Mostly city now and haven't really tracked it but probably due in part to the 245K miles. Oh my, that means OE coils!
Krons
Post by Krons »
erikv11 wrote: 31 Dec 2023, 13:32 MPGs went from 21.something to 23.something with solely swapping the coils. Same gas station, same route, same driver, across a few full tanks of gas.
Did my first drive on new coils today, still need to calculate but appears ~10% bump in mpgs like Erik. It’s a common 250 mile round trip I do regularly so a good comparison. 164k miles on origi coils.
I did go cheap with Denso coils, no issues this far and took the advice to put two of the old ones in the trunk should I be far from home and need one.
08 C702.5T (sold)
The non-Swedes:
Maybe it's an Iowa thing ... :mrgreen:
'06 S60 R, 197k
Krons
Post by Krons »
My regular 250 mile loop averaging around 65mph (some 55, some 65 limits) went from 28mpg to 31mpg. Been a while since I’ve seen it break 30 so that is a win.
08 C702.5T (sold)
The non-Swedes:
