Oil leak behind timing cover - 2007 XC70 170k miles
mtd240
Year and Model: 2007 XC70
Has thanked: 23 times
Been thanked: 7 times
Post by mtd240 »
Hi all,
I've had an oil leak on the front of the engine (timing belt side) for quite some time now. It's very slow, but I'd rather not risk a timing belt slip/snap. I'm having a hard time determining what is causing it. I've attached some pictures but I'm not sure they're all that helpful. The back of the intake CVVT gear looks suspicious -- I hope it's not that ($$$).
Any advice on how to identify this leak before I start taking stuff off? I need this car on weekdays, so I can't have it apart for long. I'm thinking of grabbing two cam seals, a crank seal, an oil pump seal/gasket kit, and a timing belt kit, and returning whatever seals I don't end up using. I probably need a new timing cover too -- it's been soaking in that oil leak for so long that it is turning into rubber :shock:
Couple notes:
Timing belt job (belt, tensioner, idler) and PCV system rebuild at 102k
Timing belt replaced (again) when I did the exhaust CVVT gear at 133.5k
Water pump: never done
Happy to answer any additional questions or take more pictures if there is somewhere I should be looking as a clear indicator of a specific leak source. Thanks for any and all help, as always.
(sorry for the pictures being upside down -- they are right side up when I open them on my computer!)
2007 XC70, white/oak, 175k miles
2008 XC70 3.2L, 115k miles
2016 XC60, osmium grey / off-black, 95k miles
Gone:
1990 240 DL Wagon, M47, lots of goodies. 372,000 miles
1978 242, lots and lots of work to get a reliable daily
1998 V70 XC, Almost done replacing everything, then I sold it :lol:
1996 850 NA, victim of sporadic tree falling. Protected the wife. RIP Volvo
timetobakethedonuts
Year and Model: '14 XC70 T6 '98 S70
Been thanked: 14 times
Post by timetobakethedonuts »
I can't tell from the pictures what is causing it. What I do recognize is your TB cover looks like mine did when my CVVT failed. One of them failed, and my Indy mechanic suggested changing both, which we did. I took the car to my Indy, and he did the diagnosis by eye that it was the CVVT. Good luck.
Krons
Has thanked: 193 times
Been thanked: 202 times
Post by Krons »
I think it is smart to change the cam seals proactively when doing the timing belt in the 200k mile range.
For sure do the water pump too. Kids 02 S60 water pump bearing went last summer at 190k and nearly lost the timing belt.
08 C702.5T (sold)
The non-Swedes:
mtd240
Post by mtd240 »
timetobakethedonuts wrote: 12 Jan 2024, 15:31 I can't tell from the pictures what is causing it. What I do recognize is your TB cover looks like mine did when my CVVT failed. One of them failed, and my Indy mechanic suggested changing both, which we did. I took the car to my Indy, and he did the diagnosis by eye that it was the CVVT. Good luck.
Ah. I honestly can’t remember how well I cleaned up the timing cover when I replaced the exhaust CVVT unit. I assume it wouldn’t be damp on the back if it was good - the exhaust side (that I replaced) is dry on the back.
Gone:
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
that hardly looks like a leak, mine was dripping on the floor and the back of the vvt hubs were wet.
mtd240
Post by mtd240 »
Maybe I ought to get a can of brake cleaner and go back in to clean it all up during the kids’ nap today. Could be that my 2018 self half-assed the cleaning when I did that VVT hub. Definitely no oil dripping on the ground, so if it’s a current leak it’s a seep.
Gone:
jonesg
Post by jonesg »
and that plastic cover will clean up nicely with some brake cleaner spray.
Been thanked: 472 times
Post by cn90 »
The CRANK seal rarely leaks before 200K miles.
Plus, you can always do this later.
Best is to replace Cam Seals x 2, VVT Hub (Exhaust side only), timing belt, WP.
I wrote a detail DIY cam seals in this forum.
mtd240
Post by mtd240 »
cn90 wrote: 13 Jan 2024, 09:11 The CRANK seal rarely leaks before 200K miles.
Thanks, I used your DIY last time I did this on a 5-cyl. Have VIDA now too 😃
Did you mean “intake” VVT hub only? I assume you don’t think I need to replace the exhaust one again.
Gone:
Post by cn90 »
Sorry, missed your post saying you already replaced the Exhaust VVT.
Cam seals: brand matters, what brand did you use?
FYI: Corteco is the genuine mfg.
I use Corteco, zero issues.
The Intake VVT: check the play.
PS: When was the last time you checked the PCV system?
