Wierd Electrical Issue
gizmaster_1
Year and Model: 850 Turbo 1995
Has thanked: 5 times
Been thanked: 3 times
Post by gizmaster_1 »
Hi all,
This morning ingot into my car and found all the of the dash guages and lights going crazy. Also there was a weird buzzing sound, like a buzzing relay noise coming from the dash. It all went away as the car warmed up but now, if I flash the high beams, the car shuts off and all the dash lights go out. It will restart fine but as soon as I hit the high beams, everything shuts down. Please Help! SEE ATTACHED VIDEO.Image
20240121_155832.mp4
(50.53 MiB) Downloaded 177 times
Has thanked: 1847 times
Been thanked: 1710 times
Bad light switch or signal/light switch lever causing shorts would be my suggestion as starters.
Next would be a bad ground somewhere.
Last would be the battery or it's wiring.
Has thanked: 1505 times
Been thanked: 3817 times
It’s a primary power problem being caused by high current draw of the high beams
Battery cables
Grounds
Bad battery
Power bus at kidney fuse box
Are the check points
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 335 times
Post by Chuck W »
The '95 won't have the "kidney box", but all of the other points still apply to check.
Check the lighting relay for the high-beams. It's located in the fuse box under the cover. (You have to unbolt the cover to access the relays)
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
Severe cold and a battery at the end of its service life will make our cars do Weird.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
abscate wrote: 09 Feb 2024, 12:19 It’s a primary power problem being caused by high current draw of the high beams
Battery cables
Grounds
Bad battery
Agreed - Begin with the Basics.
greg850r
Year and Model: a long list
Been thanked: 22 times
Post by greg850r »
I had a power steering fluid soaked alternator act that way once.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
gizmaster_1
Problem Solved! I recall a few weeks ago i had replaced the battery and only pressed the cable clams down onto the posts but did not tighten the bolts for the battery clamps. This weekend i took a look at the cables and clamps and found there was a group of 5 or 6 ground wires sitting loose due to me not tightening the bolt. My fault...OMG what a joke i am. Thank you all for the help.
Battery cables
Grounds
Bad battery
Hey, we all have moments like that! Went to use my credit card this morning and couldn't remember the pin for the life of me. Still can't!
Main thing is you remembered and fixed it. Glad it was an easy fix.
scot850 wrote: 12 Feb 2024, 13:29 Hey, we all have moments like that! Went to use my credit card this morning and couldn't remember the pin for the life of me. Still can't!
Just write it on the back in Sharpie…..
