Installing Vida 2014D for the first time Windows 10 Home
This topic is in the MVS Volvo Repair Database » How To Install Vida On Windows 10
Tanix9
Year and Model: 2010 xc90
Post by Tanix9 »
Can anyone help I have Vita dice 2014 d the life of me can’t get it to work
onkelkunckel
Year and Model: 2007 v70
Post by onkelkunckel »
Hello
I finally made the install on Window 10, but now have the problem that port 80 normally used by VIDA is used by a windows system ( not able to abort it).
I have uploaded the screen message.
Hope someone can help me!!
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
onkelkunckel wrote: 08 Mar 2022, 04:07 Hope someone can help me!!
Turn off Internet Information Services.
Active
Past
onkelkunckel
Hello Rick
Thank you so much. Worked perfect. But now I ended up with this? Hope you can help? Thanks a lot!
RickHaleParker
onkelkunckel wrote: 08 Mar 2022, 07:25 Thank you so much. Worked perfect. But now I ended up with this? Hope you can help? Thanks a lot!
Run the 2099 patch again. Reboot, wait for VIDA monitor to turn green, then try to login.
Active
Past
onkelkunckel
Hi Rick
Tried that without luck. Sorry!
AlienIQ
Year and Model: 2005 V60
Post by AlienIQ »
I keep getting this error:
The information shown below can be found in the log file,
, located in the C:\VIDA\System\Log\ directory.
Framework35 OK
Security OK
install.doinstall.3pp.components.upgrade.sqlexpress2005
An error occurred while upgrading Microsoft Sql Express 2005 to Sql Express 2008 R2.
VIDA NOT OK
When I install SQL Server 2008 (Windows 10 Home x64), in compatibility with Win 7, the error remains the same.
I also tried to install the SQL server 2005, but the installator ends at SQL server connection issue. Starting server manually didn't work as the 2005 is not installed due to this error.
And second issue, Vida installation and patch installation returned error with VidaMonitor folder not found, so I created it manually in C:/VIDA, so now the error is gone, but the folder remains empty.
Any ideas what to do with the SQL issue?
And how do I get Vida Monitor?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
RickHaleParker wrote: 08 Mar 2022, 06:47
Try this.
Also -> Amazon link
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
AlienIQ wrote: 13 Feb 2024, 14:21 I
vida monitor shows up at the bottom of your screen in the taskbar.
it will be red, then turn yellow, you have to wait until it turns green, its quite small and hard to see .
my laptop is slow, it takes a few minutes until i get the green light.
once you get the green light you can log on.
