91 740 fuel pump relay test
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
cquarts
Year and Model:
Post by cquarts »
Does anybody know how to safely check a fuel pump relay to see if it is functioning properly for a few days? I know that there is a jumper wire test that I've actually used on an 850 before but not sure how to do it on the 740. Thanks Clay
sseir39
Year and Model:
Post by sseir39 »
Check the RWD FAQ on brickboard.com They have many good suggetions. Also, the brain in these cars can give problems with starting and I have had to replace one or two.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Connect a jumper wire between between fuel injection ECU terminal #21 and earth (ground). Connect another jumper wire between fuel injection ECU terminal #20 and earth. The fuel pump relay should close and the fuel pump should run.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
