2002 V70 XC - Driver's Side Window Switch
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
1AAuto provided the removal video so I didn't document that. I used a butter knife and two long flat pieces of metal similar to spark plug feeler gauges to separate the switch cover and switch buttons assembly.
It's basically like a keyboard with a membrane separating the buttons and circuit board contacts. Used a pencil eraser to clean the membrane contacts and the board then gently wiping any residue from the contact surfaces of both. I also removed the main board to check for any signs of overheating and bad solder joints. Cleaned the ribbon harness contacts also. Just pull the brown side tabs up to release the ribbon.
I would clean the eraser frequently on a piece of cloth so it does not smear the black residue being removed. Used soap and water on the cover plate and switch button assembly making sure to dry it well. Fine grit sand paper was used to clean the spade contacts then alcohol cleaned with Q-Tips. Being the contacts are now clean and have some friction I lubricated the grey plug and flat pins so it can be separated easier.
When I reinstalled it the switch didn't function and I had a real difficult time with the grey plug so use some silicone / dielectric grease mentioned above. When I took it apart again I found the ribbon harness was loose due to not pushing the side tabs down fully. Went back in and all the buttons are functioning so far.
Driver's Window Switch 1.jpg (501.38 KiB) Viewed 295 times
Driver's Window Switch 2 Main Board.jpg (421.08 KiB) Viewed 295 times
Driver's Window Switch 3 Membrane & Contact Board.jpg (501.02 KiB) Viewed 295 times
Driver's Window Switch 4 Main Board.jpg (524.24 KiB) Viewed 295 times
You can potentially remove the switch if the Torx holding the switch is loose for some reason or else you have to remove the cover as I did. Try pulling it initially decided against it :lol:.
Antoine240bk
Year and Model: XC70 2.5T-2006 - 4C
Has thanked: 12 times
Been thanked: 30 times
Post by Antoine240bk »
Following this! I was about to change the four knobs on the driver window switch with an exciting kit PN: 31295247.
Mine are getting half broken.
Volvo XC70 2.5 T AWD P2 B5254T2 - 12/2005 Four-C Previous : Volvo V70 P1 2.4l 20s 170ch B5244S 03/2000 - Volvo 245 GL Break 1979 B21 -LPG - Volvo 240 GL Break 04/1992 B230F (Daily for 14 years)
MoVolvos
Post by MoVolvos »
Antoine240bk wrote: 04 Mar 2024, 03:32 Following this! I was about to change the four knobs on the driver window switch with an exciting kit PN: 31295247.
Those pivot switches are not cheap here but it's easy to replace. May try and find a complete one from eBay in France. The ones here on eBay are reasonably priced.
$36.95 - PART # 31295247
https://eeuroparts.com/product/genuine-volvo/31295247
US $65.00 - 01 02 03 VOLVO 70 SERIES Door Switch Front Lh (Mirror And Window) OEM: 30658146
https://www.ebay.com/itm/386825765168?f ... R-7ij8zBYw
US $55.00 - 2002-2008 VOLVO S60 S80 V70 XC90 LEFT DRIVER SIDE MASTER WINDOW SWITCH 09193383
https://www.ebay.com/itm/155589501903?f ... R-7ij8zBYw
This photo is from the $55.00 unit above. After you remove the switch just pry off the cover on both sides. Once removed using a small screw driver you can slip it under the pivot to remove the swivel knobs.
Volvo Switch.jpg (204.92 KiB) Viewed 244 times
Switch Cover & Knobs.jpg (427.14 KiB) Viewed 244 times
Swivel Window Switch Knobs.png (1.1 MiB) Viewed 244 times
Antoine240bk
Thanks for the pics! Cost of the knobs here is 38€, i will order them late spring with the maintenance items.
Looks like a fairly easy job.
