Great info and thank you for the visual.
When I remove for cleaning, do i replace the gasket with new one or reuse the existing one?
1999 S70 idle issue
- Grantkat
- Year and Model: 1999 s70 GLT
- Has thanked: 47 times
- Been thanked: 44 times
Re: 1999 S70 idle issue
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
2014D VIDA/DICE
- Has thanked: 1850 times
- Been thanked: 1710 times
Typically you can re-use the gasket. But for the work involved and piece of mind they are under $10 if I recall and there are aftermarket ones out there for less.
