Low beams and dash lights out 96 850t.
rguzz
Year and Model: 1996 850 turbo
Been thanked: 24 times
Post by rguzz »
Am away from the car but am told low beams, dash lights out, high beams work if stalk held in high beam position. Haven't asked anyone to jiggle key in the switch or play with ignition and key. Does this sound like an ignition switch going bad? Thanks.
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
Could be the headlight switch, there was a recall for some P80s. I had a '98 that did something close, swapped in a used known good one and fixed it.
Has thanked: 1851 times
Been thanked: 1712 times
Don't think the ignition key is related to this issue.
+1 on foggy's suggestion of the light switch been bad. If it was just the dash lights I would have looked at the brightness adjuster to the Right of the light switch.
rguzz
Post by rguzz »
I'll put a used one in, thanks. The ignition switch is oem and only about 5 years old.
ZionXIX
Has thanked: 65 times
Been thanked: 194 times
Post by ZionXIX »
My brightness adjust went out. I desoldered tge brightness switch off the tiny chipboard and everything works it's just stuck at max brightness now.
I've had that happen to me before. They are such a pain to remove as 99/100 one of the 2 retaining springs will snap off as the mounts are so flimsy. I glue them back on with JP Weld plastic. If I successfully remove one I still glue it!
Neil
