Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
crasbe wrote: 08 Apr 2024, 16:17 Funny, now that you said "all four", I realized that the rear has these lights as well... :shock:
One side is in perfect condition, but the other side was smashed to pieces :shock:
Unfortunately the inner plastic part that is supposed to hold the light has been detached from the door panel, so I might have to take the door panel off to glue it back on. This escalated quickly...
One way or another, I did a test fit (actually two test fits with another one pending) and it did fit quite well the first try but I optimized the shape and added more preload. It wasn't really snug.
And the repair piece got a sexy waist, which makes holding it in place while the glue dries a lot easier (and it looks good... which was the main reason I added it).
By the way: This is how "a small side project" starts to look like eventually :D
Is that UHU Hart Plastik any good? Is it a weld type glue?
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
crasbe
Year and Model: 02 S60, 98 V70 (EV)
Has thanked: 31 times
Been thanked: 79 times
Post by crasbe »
Clemens wrote: 09 Apr 2024, 13:09 Is that UHU Hart Plastik any good? Is it a weld type glue?
I can't give you long term experience, but the repair piece I glued on the light last night was preeeeeetty solid on there and it was just two little glue blobs (to be able to get it off again).
It contains Acetone, so if the plastic can be dissolved by Acetone, it probably will create a weld bond?
Check out my 3D Printed Parts for Volvo P2 and P80 on Printables :D
Clemens
Post by Clemens »
Acetone sounds good. The safer option to MEK for a lot of plastics.
Summer: 1996 855 R
Donor: 1995 854 10V
Has thanked: 1848 times
Been thanked: 1710 times
I used JB Plastic. It comes in black and beige colors. Stuck various door panels, dashboards and other plastic stuff back together with it. Not sure how easy it would be to remove, but then why would you?
RedBrickCollector
Year and Model: 1997 850 T-5 Wagon
Has thanked: 40 times
Been thanked: 28 times
Post by RedBrickCollector »
Noticed something recently, sometimes when it starts it ggoes all the way to around 3k rpm before settling back to idle after a few seconds. Trying to sarch for it gives me results for cars that rev up and don'tt go back down so I'm not sure if this is an issue
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
crasbe
Post by crasbe »
Today I found some time to print the repair clips in ABS and glue them to the lights. As I am satisfied with the fitment, the model is now published on Printables: https://www.printables.com/model/837887 ... 43-9178328
Repair clip fresh from the print bed:
Before:
After:
Best Regards,
Chris
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Looks good!
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 129 times
Post by 454cid »
Finally listed the "deer hit" S70 forsale locally. I listed it here a few weeks ago, but I'm too far away from most of you. I never thought I'd miss that car, but I've already been missing driving it, even though I've been driving the 850, which I thought I liked better.
I've Been looking at an S40, to replace it, at that the same auction house, I bought the S70 from. On one hand there are things I really am not pleased about with it, but on the other there are a few things I do like along with the better fuel mileage and use of regular gas, instead of premium. The fuel cost savings will be significant.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Ocelot
Year and Model: 1998, S70
Has thanked: 61 times
Been thanked: 17 times
Post by Ocelot »
So, today I went by an old buddy of mine in the south of the Netherlands to pick my summer rims for my S70. A while back I decided to freshen up my run down Columba wheels and thought of powder coating them. I'll post some pics when fitted on the car :D
WhatsApp Image 2024-04-15 at 14.54.44_f3861274.jpg (248.63 KiB) Viewed 3631 times
WhatsApp Image 2024-04-15 at 14.54.43_f64d1fa3.jpg (188.26 KiB) Viewed 3631 times
'Hij die zonder zonde is, werpe de eerste steen. Ik buk wel'. Simon Carmiggelt
Recent car
'98 Volvo S70 2.5 10V Europa edition (Freya)
'83 Volvo 340 DLS 2.0 redblock (Loki)
Previous owned Volvo's
'96 Volvo 440 Si 1.8
'87 Volvo 340 GL 1.7
'85 Volvo 340 DL 1.4
bmdubya1198
Ocelot wrote: 15 Apr 2024, 07:22 So, today I went by an old buddy of mine in the south of the Netherlands to pick my summer rims for my S70. A while back I decided to freshen up my run down Columba wheels and thought of powder coating them. I'll post some pics when fitted on the car :D
They look great! These are Perfos, by the way :wink:
