2004 XC70 Drive Train Removal
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 31 times
Post by cuhfs »
Any ideas are appreciated. I've been trying to remove the drivetrain. I separated the front from the haldex but the rear connection seems impossible to separate. Banged it, penetrating oil, etc. no success. Any tricks or Ideas??
Rear problem
Rear problem
Halidex remove drivetrain.jpg (150.78 KiB) Viewed 1049 times
Front
Front
Drive train 2.jpg (164.86 KiB) Viewed 1049 times
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
cuhfs wrote: 14 Apr 2024, 12:30 Any ideas are appreciated. I've been trying to remove the drivetrain. I separated the front from the haldex but the rear connection seems impossible to separate. Banged it, penetrating oil, etc. no success. Any tricks or Ideas??
Depending on amount of rust?
cuhfs
Post by cuhfs »
Thank you. I'll look at this again. If there are only 6 holes in the back of the connection then I don't understand how the bolt can press the driveshaft out since the bolt will run thru. Perhaps there are extra holes that do not go all the way thru, that I did not notice.. I Will inspect it again and report back.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
Been thanked: 4065 times
Erikv has written about this trick , maybe ping him on the details
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
Strike it gently with a brass drift several times at several locations in between the bolt holes. I’ll repeat, be gentle and persistent as. You don’t want to damage the CV joints inside. If you’ve soaked it with penetrating oil you just need to break the rust bond. The cv joint will probably come apart but you can clean and reassemble it after. What is your plan? Fluid and filter change or removal of an inoperative AWD?
2003 XC 70 (sold)
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
The flange has two threaded holes that you can use to push the CV joint out. Upon separation clean the mating surfaces good and coat with grease lightly to prevent this issue from happening again in the future.
Has thanked: 311 times
Been thanked: 817 times
On the rear CV I use an air hammer with a long pointy bit and use a socket head cap screw to drive it, have freed some pretty rusty ones that way. Be careful to not damage the Haldex parts while you are in there. Remove that DEM while you are messing around under there; be careful with the connectors. For pics showing how to use the air hammer see viewtopic.php?t=98916.
Also this thread for general tips. viewtopic.php?t=98306.
cuhfs
Post by cuhfs »
Blacklab467 wrote: 15 Apr 2024, 06:34 Strike it gently with a brass drift several times at several locations in between the bolt holes. I’ll repeat, be gentle and persistent as. You don’t want to damage the CV joints inside. If you’ve soaked it with penetrating oil you just need to break the rust bond. The cv joint will probably come apart but you can clean and reassemble it after. What is your plan? Fluid and filter change or removal of an inoperative AWD?
Plan is only removal not replacement. Car is used merely as a local runner and need to remove and fix gas tank leak. No need for AWD anymore. Has almost 300K miles on it.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
XC70Rider
Year and Model: 2007 XC70
Has thanked: 36 times
Been thanked: 42 times
Post by XC70Rider »
cuhfs wrote: 17 Apr 2024, 07:18
If never reinstalling the driveshaft then remove the DEM fuse in the trunk. That will keep the tiny oil pump from constantly running.
