2006 V70R trailer wiring
jnegomir
Year and Model: XC70 2003
Post by jnegomir »
I'm adding a hitch/wiring to my very used 2006 V70R. Next to the spare tire on the passenger side I've got a box which has a flat 5 connector going into it and nothing coming out. Ideally I can tap into this to run the wiring (no brake controller needed for this purpose). My internet sleuthing game must be weak, I've been unable to come up with what this might be and don't have my circuit tester with me. Does this setup look familiar to anyone? Thanks in advance!
Has thanked: 1836 times
Been thanked: 1709 times
Is that not the PEM controller (relay) for the fuel pump? Depending on the year it is either mounted on top of the passenger (RHS) of the fuel tank or in the spare wheel well usually on the RHS near the back.
If I recall, what you are looking for is on the LHS behind the trunk area side panel. There is, if I recall a removable panel near the rear lights that you can remove and there is a panel in there.
Has thanked: 292 times
Been thanked: 765 times
Yeah that's the PEM, don't mess with it.
See my posts on page two of this thread for the wires I tapped into for my 07 trailer wiring, it will be the same for your 06: viewtopic.php?p=596391
That video link at etrailer.com is useful too: https://www.etrailer.com/tv-install-tra ... 76kit.aspx
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 479 times
Post by jonesg »
they're pre-wired for trailers, the plug is tucked away under the plastic trim near the rear hatch catch,
I wired my own harness by jumping off the tail light wiring, when I ran the harness over to the other side I found the trailer plug, doh.
Complete waste of 2 hours soldering and heat shrinking.
Yes, that thread I linked also includes a video with the vehicle connector and very clear directions how to use it. OP can't find the connector.
'06 S60 R, 197k
jonesg
Post by jonesg »
remove the plastic trim , they tuck it way under.
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 113 times
Been thanked: 262 times
Post by Blacklab467 »
You should be able to find a factory wiring harness and or hitch at the auto wreckers, these were pretty common on xc 70's and make for an easy install.
2003 XC 70 (sold)
jnegomir
Post by jnegomir »
Thanks everyone!
