'05 V70 N/A Transmission fluid change. Disaster?
Faust
- Year and Model: xc70 2008
- Has thanked: 31 times
- Been thanked: 10 times
As mentioned, I recently acquired a '05 V70 with a little over 180K miles. I've thought to change the transmission fluid based on age. I looked at a YouTube video and they mention that a fluid change, by itself, can ruin the transmission. No explanation is offered. Is this the case? Should I simply wait until there is something seriously wrong?
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
- Has thanked: 1505 times
- Been thanked: 3818 times
Just drop 3-4 liters at a time in a series of “ drain and fills” , Faust.
The anecdotes of flushes killing transmissions are ones that are already dead.
The Toyota fluid is cheaper than the Volvo brand and I * believe* guru Jimmy57 reports Valvoline Dex VI synthetic is also fine for the P2 trans. Please check that *fact*
- Krons
- Has thanked: 193 times
- Been thanked: 202 times
I would drain and fill too. If not using Volvo fluid would also recommend Lubeguard HFM after your second flush.
my previous comments on the topic:
viewtopic.php?p=629089&hilit=Brown+red& ... e0#p629089
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- V50M66
- Year and Model: 1998 V70 AWD
- Has thanked: 26 times
- Been thanked: 89 times
Video is very wrong. Do a couple drain and fills, driving a few dozen miles between each. Get the Genuine Volvo fluid from FCP and you’ll never have to buy fluid again. Make sure to fill it through the dipstick, and reset fluid counters in vida afterwards
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
2002 S40 1.9T - daily
2004 XC70 - Mystic Silver/Black - former workhorse, parted
2005 V50 T5 M66 FWD - Black Stone/Black leather - former garage queen, sold
- jonesg
- Year and Model: 2004 V70
- Has thanked: 69 times
- Been thanked: 481 times
A transmission tech wrote "take a bit of fluid from the dipstick and rub it between your fingers, if it feels like water then the lube quality is lost, it serves no purpose to keep it in the case.".......makes sense to me.
Trans pump runs higher pressure than a flush machine, a flush will not damage anything.
The counter guys at franchise auto part stores keep repeating this stuff. They like to sound like experts.
The parrot has no song of its own.
- V50M66
I've seen them screwed up from power flushes - it's not worth the risk. Machines that use the transmission's internal pump, as well as the Gibbons method with removing the cooler lines, is fine and won't hurt anything.
Unless it's completely black and smells incredibly burned, change it.
