'05 V70 N/A Transmission fluid change. Disaster?
Faust
Year and Model: xc70 2008
Has thanked: 31 times
Been thanked: 10 times
Post by Faust »
As mentioned, I recently acquired a '05 V70 with a little over 180K miles. I've thought to change the transmission fluid based on age. I looked at a YouTube video and they mention that a fluid change, by itself, can ruin the transmission. No explanation is offered. Is this the case? Should I simply wait until there is something seriously wrong?
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
Has thanked: 1609 times
Been thanked: 4065 times
Just drop 3-4 liters at a time in a series of “ drain and fills” , Faust.
The anecdotes of flushes killing transmissions are ones that are already dead.
The Toyota fluid is cheaper than the Volvo brand and I * believe* guru Jimmy57 reports Valvoline Dex VI synthetic is also fine for the P2 trans. Please check that *fact*
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
I would drain and fill too. If not using Volvo fluid would also recommend Lubeguard HFM after your second flush.
my previous comments on the topic:
viewtopic.php?p=629089&hilit=Brown+red& ... e0#p629089
08 C702.5T (sold)
The non-Swedes:
V50M66
Year and Model: 1998 V70 AWD
Has thanked: 26 times
Been thanked: 94 times
Post by V50M66 »
Video is very wrong. Do a couple drain and fills, driving a few dozen miles between each. Get the Genuine Volvo fluid from FCP and you’ll never have to buy fluid again. Make sure to fill it through the dipstick, and reset fluid counters in vida afterwards
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
A transmission tech wrote "take a bit of fluid from the dipstick and rub it between your fingers, if it feels like water then the lube quality is lost, it serves no purpose to keep it in the case.".......makes sense to me.
Trans pump runs higher pressure than a flush machine, a flush will not damage anything.
The counter guys at franchise auto part stores keep repeating this stuff. They like to sound like experts.
The parrot has no song of its own.
V50M66
Post by V50M66 »
I've seen them screwed up from power flushes - it's not worth the risk. Machines that use the transmission's internal pump, as well as the Gibbons method with removing the cooler lines, is fine and won't hurt anything.
Unless it's completely black and smells incredibly burned, change it.
