What glue do you prefer and have had success with to bond polypropylene, which is the type of plastic used for bumpers?
I've found a few brand names such as glues made by LocTite, 3M,JB Weld and Permatex.
I'll be heading out later to see what I can find but would appreciate some recommendations...
Glueing Volvo plastics (broken bumper clips for ex)...
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
.AylmerQc wrote: ↑29 May 2024, 11:12 What glue do you prefer and have had success with to bond polypropylene, which is the type of plastic used for bumpers?
A sheet of ABS abs plastic or zip tie melted do wonders depending on the strength needed. Sometimes the repair is stronger than the plastic.
Hacksaw a small strip and melt into plastic with a soldering iron. Reinforce as needed with mesh or paper clip depending on the repair.
(www.amazon.com/Duco-Plastic-Sheet-Inch- ... 531&sr=8-3)
Watch a couple and see which repair works best for you.
https://www.youtube.com/results?search_ ... r+welding+
- Has thanked: 927 times
- Been thanked: 1001 times
Polypropolyene requires a primer before the glue. I have used Loctite 681925 with some success.
- Has thanked: 292 times
- Been thanked: 765 times
Best bet is to get the same plastic part from the junkyard, it is almost the only way to ensure you get the correct plastic that will bond well. I think the zip-tie solution will be hit and miss.
Look at the videos for how to melt it and do "plastic welding."
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- BlackBart
- Been thanked: 884 times
I bought a cheap Harbor Freight plastic welder (mostly just blows very hot air) to repair a crack in a plastic fuel tank. As said above, the correct plastic is critical - look for the manufacturing codes molded into the part. And it was a messy process - not something for an exposed finish surface.
There are some professional 3M products body shops use for bumper repairs.
- MoVolvos
Amazon link to ABS plastic in my post.
- MoVolvos
Oh sorry, an inexpensive generic soldering iron has worked well. Most come with several tips to choose from.
There are specialty soldering irons for mending plastic. As several members have stated use the same type of plastic. I'm pretty sure the ABS will work with most the plastics on our cars however.
