Seeking info on trusted aftermarket fuel pump relay
JimBee
Has thanked: 33 times
Been thanked: 43 times
Post by JimBee »
I checked the "trusted aftermarket post", very useful!
There was one fuel pump relay vendor (to avoid) I didn't recognize.
Also a search of the MVS site doesn't turn up info. I seem to recall somebody resoldered one that had failed, that post didn't turn up.
So, Volvo only? At $100 phew!
Been thanked: 4065 times
I’ve got a bunch of 99s I can send you one.
JimBee
Post by JimBee »
abscate Thanks for the offer.
The ones I've seen for the 850's are all 103's. Are the 99's same thing?
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
JimBee wrote: 30 May 2024, 14:24 I checked the "trusted aftermarket post", very useful!
ProParts is suspect, and friends don't let friends URO, ever.
I bought some once labelled Febi, turned out fine. Haven't seen any lately.
https://www.matthewsvolvosite.com/volvo ... ay-repair/
JimBee
Post by JimBee »
I got the 93 started with a known-to-be-good relay from my daily driver and it ran just fine—for about 100 yards and then died. Crank, crank, crank not even a meek little pop.
HOWEVER, the check engine light was now on, which it hadn't been when the relay flatlined, so that meant there was a possible clue in the code blinker box.
Which there was—camshaft position sensor, 2 codes. I happened to have a spare Bosch in inventory, finessed it in and voila! It seems okay now. Starts like it used to when the first plug fires.
foggydogg
Post by foggydogg »
Sometimes it takes a while for it to tell on itself. Glad you didn't have to dig any deeper.
I carry the jumper wire setup in each car; the new spare relay is in the ready position on the shelf.
