Parts failure poll: P2 Volvos: V70/S60/XC70 from 2001-2007
This topic is in the MVS Volvo Repair Database » Failed Parts Poll for P2 Volvos
What has failed on your P2 Volvo: V70/S60/XC70 from 2001-2007?
abs module
61
1%
ac compressor
62
1%
alarm system
125
3%
alternator
86
2%
axle shafts
95
2%
blower motor
65
2%
brake cylinder position sensor
18
0%
brake master cylinder
22
1%
broken ignition lock
26
1%
cabin switches
30
1%
catalytic converter
30
1%
cem (central electronic module)
33
1%
center console cover
65
2%
center console cup holder
62
1%
climate control fan
28
1%
climate system (including software upgrades)
26
1%
control arm bushings
176
4%
delaminated shoe on the parking brake mechanism
54
1%
discolored roof trim strips
112
3%
door whether strip
56
1%
engine cooling fan
29
1%
etm (electronic throttle module)
86
2%
exhaust flex down pipe
19
0%
exhaust pipe hanger broken (rusted, etc)
90
2%
front strut mounts
161
4%
front struts
147
3%
front window mechanism, slider or switch
76
2%
fuel pump
66
2%
fuel door hinge
122
3%
fuel door latch (not hinge)
84
2%
fuel tank pressure sensor
16
0%
headlamp ballasts (volvo calls them "Control units")
13
0%
headlamp leaky seal
38
1%
ignition coils
116
3%
ignition key failure (key replacement, programming)
13
0%
immobilizer antenna (start prevented error)
15
0%
lower ball joints
104
2%
lower torque rod
48
1%
oil sump seals
20
0%
other cup holder
28
1%
oxygen sensors
65
2%
parking brake cable
26
1%
passenger airbag sensor
6
0%
pcv system
123
3%
premature lightbulb/bulb socket failures
118
3%
radiator leak
79
2%
radio display
34
1%
rear view mirror
58
1%
rear bearing housing ("Knuckle")
6
0%
rear latch mechanism
27
1%
rear main seal
19
0%
seat controls cover
15
0%
seat motor
5
0%
siren control module
85
2%
spring clip to hold head light bulb
9
0%
spring seats
48
1%
steering rack
31
1%
steering wheel
4
0%
steering wheel controls
3
0%
sway bar links
135
3%
the turbocharger (whole thing)
17
0%
tie rods
128
3%
transmission (including software upgrades)
100
2%
transmission mount
92
2%
turbo valve
21
0%
turn signals
45
1%
upper engine mount
214
5%
vacuum pump/vacuum switch
18
0%
vvt solenoid
36
1%
water pump
29
1%
wheel bearings
97
2%
yaw sensor (anti-skid service required)
18
0%
Total votes: 4234
bepilot
Year and Model: 2001 S60 2.4T
Has thanked: 2 times
Re: Parts failure poll: P2 Volvos: V70/S60/XC70 from 2001-2007
Post by bepilot »
Just bought a first owner 120k km (75k miles) 2001 S60 manual 2.4T for cheap here in France, seems like I have some of those typical issues:
- worn upper engine mount
- lava auto-dim rear view mirror
- broken center cupholder-console flap
- broken fuel flap hinge
- very crumbly engine wiring casings
2001 S60 2.4T manual
It's not 'tuning' we're after, it's 'continuous improvement'...
Georgeandkira
Has thanked: 64 times
Been thanked: 69 times
Post by Georgeandkira »
Remember, people admitted to checking boxes for 2 cars OR for one car during their ownership OR one car combining the entire car's life.
Best of luck parameterizing the data.
You surely cannot be the "idiot moderator who crashed the poll" for you are the finest moderator any website could possibly have. Have a grand Thanksgiving.
Has thanked: 1507 times
Been thanked: 3823 times
Georgeandkira wrote: 21 Nov 2018, 11:17 Remember, people admitted to checking boxes for 2 cars OR for one car during their ownership OR one car combining the entire car's life.
Thats very kind, but unfortunately I am a legend only in my own mind.
:oops: :oops: :oops:
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1248 times
Post by matthew1 »
No worries, Steve. I’ll restore it from a backup.
Polls are fragile and any change freaks them out.
Also -> Amazon link
matthew1
Site Admin
Post by matthew1 »
Data restored to Nov 19 2018 on this poll. Sorry if you voted between then and today.
Moderators, please don't add options through the forum GUI. You can edit text in the textbox and the title, but not the poll itself.
We can add options, but it has to be done programmatically apparently. If we all agree that the addition(s) don't mean that the integrity of the poll is affected, let's do it. In other words, if we agree that this is just a list, not a statistically valid set of data that is dependent on the time window, let's go ahead and add items. I think this P2 poll qualifies as such... it's just a list.
Any thoughts?
Also -> Amazon link
pache11
Year and Model: 2003 xc70
Post by pache11 »
ABS module.
Passenger window sliders.
EGR hose rotted.
Bought the car knowing ABS module was bad. Ordered from Xemodex, installed and working like new. Dealer was asking $3000 for 2003 xc70 and purchased for $1900 with 105000 miles. Passenger mirror motor points at sky when unlocking with remote, believe to be be a broken wire and will repair this weekend. Sliders took only about 20 minutes to replace. Replaced EGR hose with silcone hose, 5 minute repair.
ADent
Year and Model: 2001 V70 T5M
Been thanked: 5 times
Post by ADent »
Things not on the list - ignition switch, rear window regulator.
I selected PCV for the split J-hose.
2001 V70 T5M
1988 740 GLE 5.0
matthew1
Site Admin
Post by matthew1 »
Bump for anyone who's never seen this Mother of all P2 Parts Polls™.
Also -> Amazon link
BlackBart
Has thanked: 927 times
Been thanked: 885 times
Post by BlackBart »
Interesting to me that almost all of the high point items on this chart (except alarm??) are normal maintenance, wear & tear items, not poor design, engineering faults, or assembly quality.
matthew1
Site Admin
Post by matthew1 »
There are so many takeaways from this poll's data it's hard to organize my thoughts and write them all down, but I think my #1 takeaway is this: cars are heinously complex machines.
Also -> Amazon link
