v70 back on the road
johnrapier
Year and Model: 2001 Volvo V70 T5
Post by johnrapier »
My 01 v70 2.3 t5 has been sitting under a tarp for about 3.5 years now. I just fired it up and it started right up. Going to flush all the fluids etc. My main question would be.
Should I replace the calipers all the way around as I'm concerned about them possibly seizing? Or should I just run it up and down my driveway a few times and if the brakes grab and release will it be ok?
Also is there anywhere to get the replacement front windshield window trim.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
examine the rotor faces thru the wheel spokes, run it and brake until the rust is gone.
check the temps of the disks, any that are sizzling hot i would clean the slide pins and lube, or do them all anyway.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Of all of the cars I have moved after being parked for years, only one had brakes locked. If everything checks out with the rest of the car, then flush the brake fluid at each caliper. If they will not flush, you know you have a problem.
