I got 2 new keyfob cases from China, as the keyfobs are the most worn part of my recently-acquired 2010 v50.
But I can take the electronics alone, without the grain-of-rice transponder, and unlock and start my car!!!! (The siren module in this car has a dead/non-chargeable battery that needs replacement, but other than that, there are zero VIDA DTCs set.)
I cut the old one apart, and transferred the guts to the new plastic, with buttons that had color on them. But the grain of rice transponder... I wondered where I could put that INSIDE the keyfob, so that I could cut off the plastic "neck" of the key, and just use the "knob" key that I leave in the ignition, so I temporarily taped it to the side of the case, and went to start the car, and started it. But I realized that I had taped the transponder to the case I had left on the workbench, and had just started the car without ANY transponder at all.
The photo below shows, starting at top left, and going clockwise, the transponder, the knob, which one assumes must have its own transponder, the top of the new keyfob case, and the bottom of the keyfob case, WITHOUT the transponder installed in the recess of the fake "key" part of the keyfob.
So, leaving the knob and the transponder inside, I can use the keyfob to lock, unlock, hold the unlock down to both unlock and roll down the windows, all the usual stuff. AND I can START THE CAR!
Now, on previous drives, using the knob, and keeping the keyfob in my pocket, if I get out of the car with the engine running and walk away any distance, the car detects that the keyfob has left the car, and chimes and complains about that. So the car knows electronically, far beyond the range of the grain of rice, which explains how I can open locked doors with the keyfob in my pocket by simply approaching the car. But is the grain of rice "chip" now obsolete? Why is it included then?
I am so very confused. No way that the previous owner modded anything in this car, he had everything, even tires, done at the stealership. There is no way that there is an extra grain of rice chip "inside the coil" behind the dash.
How can this chipless fob be starting the car? I am afraid to cut off the fake-o "key" part of the fob as I wished (to make a more pocket-friendly keyfob).
Mystery - I Can Start my 2010 v50 WITHOUT the transponder grain-of-rice "chip"????
- packetfire
- Year and Model: 2010 v50 2.4i
- Has thanked: 17 times
- Been thanked: 30 times
1982 240DL: Drove it 32 years and 1.5 million miles (sold, even still had mint leather!)
2001 v70 2.4T: The most expensive $1500 car I ever bought ("Volvo Turbo" - what an oxymoron!) (sold)
2004 v70: Far less fatally-flawed v70 - It served well (sold)
2010 v50: Smaller, slightly sportier wagon. Its got a spoiler, so I upgraded with sway bars!
- 11 Replies
- 17889 Views
Last post by kcodyjr
- 1987 Views
Last post by volvolugnut
- 3457 Views
Last post by cn90
- 11 Replies
- 2625 Views
Last post by xyourobob
- 1142 Views
Last post by matt122s
