98 S70 misfire chasing
Cadywampus
Year and Model: 98 S70
Post by Cadywampus »
I'm chasing a stubborn misfire issue on a 98 S70. Actually it is a multiple misfire according to the error codes. Weird thing is it only happens when you accelerate hard, you don't feel it misfiring, and it only pops the check engine light. Driving mildly there is no problem, but get on it and bam ...check engine light. When you scan it is always a multiple cylinder misfire but different cylinders misfiring each time. Compression is fine across all cylinders, the plugs, wires, and injectors were changed but it still has the issue. I'm leaning towards the distributor cap, rotor, or coil since they older parts.....any other suggestions?
Has thanked: 292 times
Been thanked: 765 times
I'd also check the fuel pressure, you need a pressure gauge to get any useful information. But never any lean codes, just misfire codes?
The rotor can definitely fail internally and affect all cylinders, so that's a possibility yes. I'd be looking to get a new Bosch cap and Bosch rotor, agree with that.
Bad coil is rare on these cars, seems least likely.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Injectors?
CEL should be blinking when misfire occurs and stay solid after misfiring stops.
Bad Maf,it's wiring or connector could cause a misfiring too.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1500 times
Been thanked: 3810 times
Plugs and wires too!
Open up that cap and see if its full of moisture from a seeping cam seal
foggydogg
Has thanked: 83 times
Post by foggydogg »
Cadywampus wrote: 01 Aug 2024, 20:31 I'm chasing a stubborn misfire issue on a 98 S70. Actually it is a multiple misfire according to the error codes. Weird thing is it only happens when you accelerate hard, you don't feel it misfiring, and it only pops the check engine light. Driving mildly there is no problem, but get on it and bam ...check engine light. When you scan it is always a multiple cylinder misfire but different cylinders misfiring each time. Compression is fine across all cylinders, the plugs, wires, and injectors were changed but it still has the issue. I'm leaning towards the distributor cap, rotor, or coil since they older parts.....any other suggestions?
Add one for inspecting the cap and rotor; as Dr. Abscate suggests, a little spooge inside the cap can cause spark dancing.
Random cylinder misfiring on hard pulls can be diagnostic for a vacuum leak as well.
rguzz
Year and Model: 1996 850 turbo
Been thanked: 24 times
Post by rguzz »
Start with the inexpensive stuff, clean up cap, rotor. Next might be vacuum leak agree with last post, also not expensive. I'd go there next, inspect hoses at turbo, tcv. Replacement Bosch cap is over 100 bucks?? Not to mention wires, etc. though you just replaced them I gather, oem parts?
Bosch cap under $60 at FCP Euro. Rotor $30.
'06 S60 R, 197k
