Blind rivet spec Volvo P/N 982 565
beewstew
- Year and Model: 2004 xc70
- Has thanked: 34 times
- Been thanked: 5 times
What are the dimensions of Volvo's "blind rivets", part number 982 565 used for fender liner and similar trim pieces? Are they simply black 1/8" diameter, 3/8" depth aluminum pop rivets?
They are special design with plastic parts that break, rather than break the liner.
In good climates you can use standard rivets, but if you are in places where salt and ice accumulate, use the right Volvo ones.
- Has thanked: 2199 times
I've repeated this often, if you use aluminum regular rivets, don't use mud flaps on your car. If you do and they ever catch on anything they will bend panels badly!! You are warned!! Driving over a curb is enough to do this whatever you live. Up here in the north I use the Volvo style ones, but I bought them from I think it was eEurosparts for about $0.30-0.40 each. They may not be as well finished as the Volvo ones but do the same job.
- 1259 Views
Last post by zooklm
- 1934 Views
Last post by Capndirk
- 3633 Views
Last post by pierremcalpine
- 1351 Views
Last post by FenFen
- 11 Replies
- 1597 Views
Last post by SuperHerman
