ECU/TCU removal from a P2 - How? Topic is solved
Has thanked: 1853 times
Been thanked: 1714 times
I see that you can get a special tool to remove the ECU/TCU from a P2 Volvo. I want to pull these from the 02 XC70 I am working on as there looks like steering oil has got into the case and I am getting ECU error messages.
Is there anyway to do this without the tool? The only tools I can find up here seem to be the CTA tool which Amazon wants to rip me off for around $80 and 2 week delivery.
I need to so the job now, not in 2 weeks. Is there any safe way to do this without the tool?
I'm also going to disconnect the battery to remove this and give it a few minute for systems to discharge before trying to remove them.
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
Has thanked: 1507 times
Been thanked: 3822 times
Peppermint to the rescue!
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 175 times
Post by dikidera »
I recommend a T25 torx (in the shape of an 'r') for getting it inside the rails and a long flat screwdriver with which to push the other rails. Works every time for me and I've had them out at least 10 times.
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
scot850 wrote: 04 Sep 2024, 00:10 I see that you can get a special tool to remove the ECU/TCU from a P2 Volvo. I want to pull these from the 02 XC70 I am working on as there looks like steering oil has got into the case and I am getting ECU error messages.
ONLY 1 LEFT
ECU Removal Tool, 9995722 Automobile Maintenance Replacement Computer Control Box for S60 V70 S80 XC90
Visit the Akozon Store
$31.40
FREE delivery Sunday, September 8 on your first order
Or fastest delivery Tomorrow, September 5. Order within 4 hrs 35 mins
https://www.amazon.ca/Removal-Automobil ... 108&sr=8-1
MoVolvos
Post by MoVolvos »
dikidera wrote: 04 Sep 2024, 04:07 I recommend a T25 torx (in the shape of an 'r') for getting it inside the rails and a long flat screwdriver with which to push the other rails. Works every time for me and I've had them out at least 10 times.
I have the CTA from FCP and I sometimes still have trouble with it :lol:.
dikidera
Post by dikidera »
I forgot to mention. The covers need to be removed aka the box itself for my method to work.
Guys, as usual you are awesome! All this is great. I may still go ahead on the Amazon one. However, I was talking to my ex-Volvo mechanic buddy and turns out he has one I can borrow! I can pick it up tomorrow which is great.
I have read many mixed reviews on the quality of the aftermarket tools for this, so not sure if the Akozon one is any good as there are no reviews. Ok, I'll buy it and compare with the loner I get and see how they compare. I can always return it if it is bad!
Dikidera, that is a good suggestion too. I might try that as well and cover all the bases. I plan to remove the box and the power steering fluid out the case while it is apart.
Now onto the next issue! New thread help request coming!
MoVolvos
Post by MoVolvos »
scot850 wrote: 04 Sep 2024, 15:00
Perhaps you can provide links on all your Subjects / Threads done to the car in one post so it's chronological besides work done with the car?
viewtopic.php?t=105191
When I did this in the past, when I needed help, no one was responding. What I am trying to do this time is to add links to the break out questions on the time lines. Not ideal, but I'm hoping once I get the engine stuff figured out (or not) the rest will be more plain sailing and will all be in the main thread.
Criticism is fair, but like I said I need to get eyes on specific issues to move this on. Hopefully with a bit of luck I will make some headway on moving on from the engine shortly!
