2004 Volvo V70 Rear Dust Shield
mnmk
Year and Model: V70 2004
Post by mnmk »
Rear dust/splash shields are rattling.
Can these dust/splash shields be taken off and not replaced?
Do I need them?
Thanks!!
Has thanked: 2207 times
Been thanked: 1852 times
Can you post a picture as I can't think of what you are talking about to advise you on if they are delete-able?
mnmk
Post by mnmk »
Thanks for the reply. I attached a photo for you. It is the thin metal shield behind the rear rotor. It is held on by four small bolts. It just seems unnecessary, but I just want to make sure before I do anything.
Thank you very much!
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
mnmk wrote: 15 Dec 2015, 16:54 Thanks for the reply. I attached a photo for you. It is the thin metal shield behind the rear rotor. It is held on by four small bolts. It just seems unnecessary, but I just want to make sure before I do anything.
Can it be removed without removing the hub?
Paging @scot850 regarding viewtopic.php?p=419882#p419882
also found info here : https://www.volvoxc.com/forums/showthre ... post196929
04s60 2.4
04xc70 2.5t
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
mnmk wrote: 14 Dec 2015, 16:37 Rear dust/splash shields are rattling.
Do I need them?
Thanks!!
yes you need them, the Ebrake shoe retainer slots are on the shield.
make sure the dust shield isn't rubbing the brake drum, if the bolt holes are rounded out add fender washers.
your shield is in good shape compared to mine.
The guys have already answered the question that they are needed. However, while you have it in bits, check the aluminum foot for for the parking brake shoes. In salty areas or where salt is used on the roads, that aluminum peg can become severely corroded interacting with the steel of the brake shoes and the metal backing plate. In worst case they can literally disintegrate causing the shoes to detach and wreck the read hub. If there is any doubt there are steel replacements available from the likes of Skandix and Ebay.
jonesg
Post by jonesg »
br0dy519 wrote: 03 Sep 2024, 09:02
nope.
br0dy519
Post by br0dy519 »
scot850 wrote: 04 Sep 2024, 00:17 The guys have already answered the question that they are needed. However, while you have it in bits, check the aluminum foot for for the parking brake shoes. In salty areas or where salt is used on the roads, that aluminum peg can become severely corroded interacting with the steel of the brake shoes and the metal backing plate. In worst case they can literally disintegrate causing the shoes to detach and wreck the read hub. If there is any doubt there are steel replacements available from the likes of Skandix and Ebay.
Any thoughts on my question regarding leaving the hub in place while replacing this dust shield?
04s60 2.4
04xc70 2.5t
I don't believe you can. From your picture, it looks like the 4 bolts holding the hub in place will prevent you doing that. Is the picture of your back plates/dust shields? If so, they don't look rusted, so why are they rattling? Are you sure it is them?
