05 V70 fuel pump wiring
Faust
Year and Model: xc70 2008
Has thanked: 31 times
Been thanked: 10 times
Post by Faust »
I finally got my known good fuel pump installed, but no luck, won't run. So now I am checking electrical issues but don't have a wiring diagram. Can anyone tell me color of the power wire to the pump motor? This is a steel tank car with the pump and sensor together on one side.
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
Faust wrote: 19 Sep 2024, 18:33 I finally got my known good fuel pump installed, but no luck, won't run. So now I am checking electrical issues but don't have a wiring diagram. Can anyone tell me color of the power wire to the pump motor? This is a steel tank car with the pump and sensor together on one side.
big blue wire should be 12v feed, black is ground.
watch Ivan work his waY through this no start pump problem.
Has thanked: 1507 times
Been thanked: 3824 times
White
White black to the pump.
Here’s the 2005 piece of wiring diagram, pump is 6/33. The PEM unit is shown above.
Check the threads to make sure the pump takes 12 volts as it’s PULSE WAVE MODULATED
