Check your Banjo PCV bolt
Has thanked: 311 times
Been thanked: 817 times
Yes and yes.
Our black 07 XC70 is currently (still) laid up until I pull the top apart, but all indications are that the little piece got pulled in to #3 and is bouncing around on top.
viewtopic.php?p=632220
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
erikv11 wrote: 30 Sep 2024, 15:36 Yes and yes.
A little lazy to research and read so appreciate if you can tell me which years have the bad banjo bolt? Currently in the fleet.
Running
00 S70 SE NA
02 V70 XC 2.5T
09 S60 2.5T AWD
12 XC90 3.2 AWD
Non-Op
07 S60 2.5T
MoVolvos wrote: 30 Sep 2024, 16:02 ...
A little lazy to research and read so appreciate if can you tell me which years have the bad banjo bolt? Currently in the fleet.
Running
00 S70 SE NA
02 V70 XC 2.5T
09 S60 2.5T AWD
12 XC90 3.2 AWD
Non-Op
07 S60 2.5T
I don't know! And you'll find conflicting info online. However consider that the go-to Pine Hollow videos (see post up-thread by jonesg) are dealing with an 08 S60, to me that says clearly that all P2 are suspect, and probably beyond. I'd take a look at the bolt on your 09.
MoVolvos
Post by MoVolvos »
erikv11 wrote: 30 Sep 2024, 18:49
Running
00 S70 SE NA
02 V70 XC 2.5T
09 S60 2.5T AWD
12 XC90 3.2 AWD
Non-Op
07 S60 2.5T
Hoping my 02 V70 XC like darylrobert won't need it but I'll check all 3, the 07 and 09 S60. Thank.
viewtopic.php?f=9&p=575593#p575593
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
Rvolvos wrote: 18 Jun 2021, 23:54 Did check the banjo bolt on our V70 today, pcv was serviced by the dealer with previous owner.
Used a mirror, a bright light and my phone to make a picture of the mirror, so that I could zoom in.
Luckily it is the later style marked with 2014.
Nice job. Yesterday I tried to get a light and a mirror close to it. All I can see is the side of the bolt head, so it's still a mystery.
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
I think they all had the failure prone one originally until an update became available about 5-8 years ago. FCP should be able to provide a part number or a call to the local or nearest Volvo dealer.
2003 XC 70 (sold)
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
P/N for updated 2020 bolt 31325709
04s60 2.4
04xc70 2.5t
DavidE7
Year and Model: 01-07 V70, S60, XC70
Has thanked: 67 times
Been thanked: 93 times
Post by DavidE7 »
This forum posting for a disassembled PCV check valve banjo bolt was key for me to figure out what happened to my 2007 Ti S60 that had bad compression on cylinder 3.
After a bunch of research, I opened the engine and found damage from the pin and ball:
I purchased a replacement head at a pick-n-pull junkyard along with a like new PCV system. The valves were all cleaned, seats and valves lapped, valve stem seals replaced, and clearances verified to all be in tolerance for the solid tappets.
The protrusions on the piston were all smoothed.
Then I learned that the PCV valve guts had also gone through to the turbo:
I got a turbo out of a low mileage junkyard car and rebuild it with a kit recommended on this site. (Soaking in strong phosphoric acid does a great job removing the buildup of exhaust contaminants on the impeller.)
I temporarily used a PCV check valve from the junkyard car and then replaced it with the new design check valve. Here is a complete lineup of the 4 Volvo P2 platform banjo bolt versions that you will encounter:
[attachment=0]Banjo_Bolts.jpg[/attachment
The information on this website plus Vida/Dice, junkyard parts, FCP Euro parts, and a bunch of new tools and time got my S60 back on the road.
I hope this post helps some other Volvo owners get the message that replacing your PCV banjo bolt is a very good idea!
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 231,000 miles
2004 Nautic Blue XC70 2.5T 258,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 277,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 203,000 miles
P2 Volvos for every person in my family
Krons
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
How many hours of work to replace the banjo bolt? Looks like access is removing the steering pump and removing with ratcheting box end wrench?
Asking as I know the PCV job is quite a chore.
08 C702.5T (sold)
The non-Swedes:
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Krons wrote: 29 Mar 2025, 07:51 How many hours of work to replace the banjo bolt? Looks like access is removing the steering pump and removing with ratcheting box end wrench?
Need to unbolt alternator and shift it to left as well.
