- Evaporator/dryer replaced by me circa 2016
- A/C worked for many years
Now, with new compressor and dryer, I pump it down. Leaving the gauges hooked up and pump off, the system holds vacuum for 30+ minutes. However, removing the low pressure charge port connector while the system is under vacuum, the recharge point is drawing in air via the valve stem. I replaced the valve stem and it still does the same.
Question, is this normal behavior or is there still something wrong with the valve stem? I'm concerned if I recharge system with 134a it will just blow it out the valve stem.
