98 S70, has had a EVAP leak P0445 for about a year. Finally dropped the tank today and found an EVAP hose on top of the tank, cracked at one of the clamp locations. The hose is between 6 - 7" in length, one end appears to be close to 5/8" I.D. and the other is close 3/8" I.D. (Actual measurements might be closer to 18mm / 11mm)
I've read that this hose might be out of production now. As a last resort, I have a brass barbed adapter, 5/8 to 3/8, and can make up a hose to work, but would like to know what others have done.
EVAP hose?
- Has thanked: 1853 times
- Been thanked: 1714 times
Sorry, but no obvious suggestions as to how to fix this. There is a similar but much longer pipe on the P80 AWD cars on the top of the tank. I have read of that being repaired in a similar method to what you are suggesting. Hard part is the short length you have to work with.
I'm wondering if a silicon pipe suitable for fuel (do they exist) and buying it in the smaller pipe diameter and then heating the other end in boiling water first and seeing if it will expand enough to fit over the larger diameter?
I appreciate you talking about this as I have a feeling I have a friends P80 wagon that may have the same or similar issue as I can't find any leak anywhere else.
rick4484
- Year and Model:
- Has thanked: 59 times
- Been thanked: 10 times
I've been on the phone and scouring the web to see if this hose is in stock somewhere, but no luck. I think it's Volvo Part #9463088, now discontinued. I'm not sure of the I.D. of this hose. The brass adapter I have (5/8" to 3/8") seems to loosely fit inside the old hose, so I suspect it's a metric size rather than imperial. Possibly at 15 - 9 mm instead. So, I think the only option will be to make something using an adapter.
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 131 times
I recently got this code, too. I have not attempted to find the leak, yet
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Where in the world are you Rick? I just put the part number you posted and it came up at several places in Europe and US. Now if they actually have it may be the question:
https://www.pelicanparts.com/More_Info2/9463088.htm
https://www.rendcarparts.com/parts-for- ... RD9463088A
https://www.skandix.de/en/spare-parts/b ... zmWhCGIED3
https://classic-volvo.com/brandstof-ont ... 63088.html
https://partsinn.lt/?oem=9463088
- Has thanked: 1506 times
- Been thanked: 3822 times
I can probably tank drop Shagg and see if I have that hose in decent shape this weekend? I also have a couple dropped tanks upstate as well
You taking to stripping airplanes now with drop tanks??
rick4484
- Year and Model:
I'm in the US. I called Pelican yesterday because I also saw the part on their website, they don't have it either. I see the part on many European sites, but rather than having something shipped across the pond, I'll just make a hose with an adapter and be done with it.
Please post the solution once you figure it out. It will help others (possibly me as well) to find a way to fix this issue.
Good luck!
Good luck!
- 13 Replies
- 6046 Views
Last post by VolvoBoron
- 1032 Views
Last post by JRL
