DIY: 1998 S70 GLT Documenting Vacuum Hoses [Turbo]
Vacuum Lines on Turbo 1993-2000 850/S70/V70/XC70
shegarty
- Year and Model: 1998
- Has thanked: 12 times
- Been thanked: 8 times
Any resources out there listing what size of hoses are required ... particularly for those lines related to EVAP? I am currently chasing the P0455 code
98 S70 T5 SE 298k km (daily)
87 740T sedan (current project)
previous - 90 745T; 94 855 T5
combatkarl
- Year and Model: 1997 850 GLT
Another great post with photos. I found a quick fix to replace hose #1 from the intake manifold to the "fuel rail" tube. At the auto parts store, I found Item # 47092 Vacuum Elbow 1/4" from Dorman Help! products. Any O'Reilly or Advance Auto should have it. I tried a straight piece of vacuum hose, but was not happy with the results or kink in the hose. The attached photo has the the hose is highlighted - ignore the red arrow.
- Intake Elbow.jpeg (132.2 KiB) Viewed 6409 times
Karl
1997 Volvo 850 GLT
2001 Honda Odyssey
1999 Mazda Miata
2012 Dodge Journey
1984 Honda Nighthawk S bike
1997 Volvo 850 GLT
2001 Honda Odyssey
1999 Mazda Miata
2012 Dodge Journey
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
I replaced my hose as well, Volvo doesn't seem to carry it: I tried my dealer. I was able to carefully bend a stock piece of vacuum hose. No kink.combatkarl wrote:Another great post with photos. I found a quick fix to replace hose #1 from the intake manifold to the "fuel rail" tube. At the auto parts store, I found Item # 47092 Vacuum Elbow 1/4" from Dorman Help! products. Any O'Reilly or Advance Auto should have it. I tried a straight piece of vacuum hose, but was not happy with the results or kink in the hose. The attached photo has the the hose is highlighted - ignore the red arrow.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
shegarty
Same here, used braided fuel line which was what I could get my hands on and looped it around to avoid a kink on the tight radius - make sure to avoid leaving it too long or it will get caught in the fanmecheng wrote:I was able to carefully bend a stock piece of vacuum hose. No kink.
- Has thanked: 311 times
- Been thanked: 817 times
Silicone vac hose is great for keeping shape through bends.
Do you mean the SAS valve? If you have it off, consider getting rid of it altogether. It's one of the first things I do when I get a new P80 car.
http://volvospeed.com/vs_forum/topic/14 ... with-pics/
toatesarchitecture
- Year and Model: 1998 V70 T
I have a 98 V70 T project car - that started with no engine, and I put a 98/99 T engine in and need help with routing of vacuum lines. I may have extra pieces I dont know about, or missing T's and check valves. I've read every post and still am confused about what goes where. So I drew my own diagram - so if someone could connect the dots I'd be golden. I'm trying to attach it to this post, fingers crossed. John
This is the best, with the only ambiguous one being the blue turbo hose. That plugs into the nipple on the air box hose , down hear the turbo.
You might have some things to Klooge if it’s a 99 motor, specifically
Sas air injection, none on 99
Fuel pressure regulator ( none on 99, needed on 98)
Crankcase Pcv different
Turbo control valve different
Purge valve may be different
- 26 Replies
- 5163 Views
Last post by polskamafia mjl
- 32 Replies
- 17636 Views
Last post by sleddriver
- 62 Replies
- 5657 Views
- 16 Replies
- 3445 Views
Last post by southofmotown
- 760 Views
Last post by tanelus
