Yeah I was having pretty similar issues, especially having to open the throttle to get the engine to turn over. It's not even able to start at this point.lrock wrote: ↑19 Nov 2024, 13:33I usually just grab a pencil gauge for $1-2; only use it for the fuel/EVAP system and toss it at the end of the day.
I use shell 93 and every time I fill I have to let it crank for longer than usual and open the throttle or it wants to shut off, idles super rough. Do you have a similar experience?
Do you have any way of pulling data, either vida or Bluetooth obd2 dongle?
I've got an Obd2 but don't have vida. The last shop I took it to (only one I know of in my area that still has Vida other than dealerships) said they ran it and everything looked fine other than a stored camshaft sensor code. Frankly I'm a bit suspicious of how closely they looked into it cuz the car is far from fine. They just slapped a new battery in and said the fuel pump needed to be swapped. So after doing that and the relay, cleaning the injectors, and new plugs the car started getting multiple misfires and now can't start.
Still don't have a clear read on fuel pressure as the gauge I ordered had the wrong size schrader valve and I'm picking a new one up tonight. Tried a Pen gauge but it seemed pretty sketchy at best.
