98 v70 intermittent fuel delivery (?) problem
Andrewoakland
Year and Model: 98 v70
Has thanked: 3 times
Been thanked: 6 times
Post by Andrewoakland »
Hi. I recently inherited a 98 v70 (wagon). Mileage 150k. Well maintained and have all service records. Twice in the past 12 months, the car either failed to start or stalled out after short trips of 5 blocks or so.
First time, I turned the engine off and returned to the car after about 15 minutes. When I turned the key, the car shuddered and started briefly then died. When I turned the key after that, if i just quickly hit the starter, I'd get a brief rumble then nothing. If i turned the starter over for more than 2 seconds, i got nothing. I tried it again over the next 2 hours, same result each time. Had to tow it home. About a week later I tried it again, and it worked fine.
Second time, my daughter stayed in car and left it running while I went to a shop for 5 minutes. I came out and when I put the car in drive, it shuttered and died. After it died, same experience as the first time. Quick hit on the starter, brief rumble then nothing. This time, though, I tried it again in an hour and it worked fine.
Other than these two instances, I have driven it at least twice a week with no issues.
Best way I can describe it's like running out of gas when this happens. It has lots of gas, and lots of battery. Since I bought it I had the PCV system overhauled and the fuel filter changed. Didn't help this problem.
I would sure appreciate any advice. thanks, folks.
Andrewoakland
By the way, these two incidents were months apart.
jmartin919
Year and Model: S70 GLT SE 2000
Has thanked: 97 times
Been thanked: 42 times
Post by jmartin919 »
Fuel pump relay?
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
Andrewoakland
Thanks Jay. I'll check it out. You think a bad relay could be intermittent like this?
Been thanked: 4068 times
Yes, it definitely can be.
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
The fuel pump relay on my 97 855 did the same thing recently. I jumped it with a bypass wire and verified the jumper prevented the stalling problem. Then I bought a new relay and installed it... has been working fine since then.
Andrewoakland
Thanks fellas. Couldn't be an easier or cheaper fix than replacing the fuel pump relay so ill give that a go. Is there any way to check the old one after I swap it out to verify that it is bad? So far the problem has been so intermittent (1 out of 200 or so starts) that bypassing the ld one won't give me much information, Im thinking, since it is likely to work with or without the bypass. I'd sure like to confirm the realy as the problem if possible, so i can trust the vehicle again. Again, really appreciate the insights on this.
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
Andrewoakland wrote: 05 Jan 2025, 17:17 Thanks fellas. Couldn't be an easier or cheaper fix than replacing the fuel pump relay so ill give that a go. Is there any way to check the old one after I swap it out to verify that it is bad? So far the problem has been so intermittent (1 out of 200 or so starts) that bypassing the ld one won't give me much information, Im thinking, since it is likely to work with or without the bypass. I'd sure like to confirm the realy as the problem if possible, so i can trust the vehicle again. Again, really appreciate the insights on this.
Just open the relay its nothing specially sealed on 850 just clipped.
For me here cold environment it had got very crusty after all the time existing. Re soldering with flux and cleaning and maybe replacing the capacitor it is good as new apart contact surface its slightly dirty but i didnt see it any bad personally. I would say all of them are bad due age at this point and should be checked and maintained.
Stick with the OE relay, about $50. The FAE relay has a poor track record here, like a lot of aftermarket parts
eBay Amazon stoned auto pep boys green/ orange flagged parts URO are to be avoided
jreed
Post by jreed »
Agreed with above about FAE... On the OEM relay, the solder joints crack:
Volvo850FuelPumpRelaySolderJoint Cracks Circled 1.jpg (66.57 KiB) Viewed 1101 times
I've seen this on Volvo relays from the 1990's and from the 2010's... we'll see if the one I recently installed holds up.
