Compatible 2013 contactless ETM for older S70?
Do you have a failing Electronic Throttle Module? What steps to take if you do, plus the latest ETM news. Volvo 1999-2002 models only please.
800artfreed
Year and Model: 98 S70T5; 99 S70GLt
Been thanked: 26 times
Post by 800artfreed »
In other parts of this site someone mentioned replacing an old ETM with a contactless 2013 ETM. This would be great as the PnPs in my area don't care what the specifics of the part you pull, just the general label that it is an ETM for about 30 bucks.
Does anyone have a compatibility list for newer to older cars. I have a 1999 S70-GLT (2.4L) engine. Would any 2.4L, 5 cylinder 2013 ETM let's say from a S60 work on this older car? Would the VIN need to be programmed into the ETM?
Thanks for any insights you might have
VolvoVoyeur
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
Has thanked: 1505 times
Been thanked: 3817 times
The newest version apparently has software that works with both turbo andNAcars.
So far , I am 3/3 with a drop in replacement with no software.
dikidera
Year and Model: S60 2005
Has thanked: 67 times
Been thanked: 175 times
Post by dikidera »
abscate wrote: 27 Jul 2022, 02:53 The newest version apparently has software that works with both turbo andNAcars.
What does 3/3 mean in this context? You have the part, but not the software and thus can't use it?
dikidera wrote: 08 Dec 2022, 12:38
3 installed later ETMs. 3 successful installs with no software needed
lrock
Year and Model: 2001 v70 xc
Has thanked: 9 times
Been thanked: 37 times
Post by lrock »
Will these drop into a 2001 v70, or is it just <2000 ?
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
I'm curious about this as well. What years are switchable ?
1999 V70 GLT
The Magneti Morelli style Electronic Throttle Module was only used on 1999,2000 models (up to 2004 for the C70) and more models in EU, like LNG cars.
A 2001 in North America will use the Bosch Electronic Throttle Actuator, it’s a completely different technology, all together
