Hi CN90, if you are referring to my situation, it is a whining rear diff, we had it up on the hoist over the weekend. Not looking forward to the repair.cn90 wrote: 08 Sep 2024, 10:12 I am afraid your problem is a stripped sleeve and not a rear diff.
Correct diagnosis is important.
XC90 rear differential replacement - questions
Stovinator
- Year and Model: 142e, 1972
WrenchBoy
- Year and Model: 2007 XC90
- Been thanked: 2 times
I would say any "used" unit you buy is going to have a failing Pinion Bearing. I bought a unit off eBay $558 CarPartsInc, Pittsburgh PA the the pinion bearing was failing. I am in the process of rebuilding the unit with new Bearings, Seals. Had to purchase the Pinion Nut Tool off Amazon at $157, it worked well. I am going to use a digital inch pound torque wrench to help me set the preload, by using the Pinion Nut splined portion, setting the torque wrench to 9.7 inch pound and then rotating the shaft, re-tightening nut as needed until resistance is achieved.
- Been thanked: 4064 times
Oh, unhappy roller bearings!
Those must have run dry at some point
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 26 times
- Been thanked: 134 times
Thanks Paul.
It's a common issue, just most folks never get it that bad or, like me with two slightly ringing rear diffs at 50-ish mph on a quiet road, just leave it alone (I'll probably get them repaired someday). I change the fluid myself so they're always full- it's a design issue, well recognized as Paul demonstrates and something that has been around for many years. With a 2013 abscate, you're likely in the clear.
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
Some more links
https://www.freel2.com/forum/topic34201.html
https://www.freel2.com/forum/topic29861.html
I use a gear oil with better protection for shock loading
Mobil Delvac 1 Gear Oil 75W90
You won’t find it in a typical auto parts store.
I ordered mine from a place in Chicago I think
Good luck
Paul
PS I do recommend that a magnet is used for any differential to remove the steel particles that will always be present
Good luck
Paul
- 1809 Views
Last post by ylwgto
- 1929 Views
Last post by MDK
- 3217 Views
Last post by jimmy57
- 733 Views
Last post by yanga001
- 876 Views
Last post by LuthierIan
