96 R Center console
- Clemens
- Has thanked: 473 times
- Been thanked: 219 times
96 R Center console
The back part of my center console is broken. the po managed to ruin the area where the arm rest hinges attach to. is the R specific walnut trim an insert into the large console or is it one piece? wondering if i can replace the console with a regular one and just transfer the walnut inlay. does anyone know if these walnut inlays pop out?
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Donor: 1995 854 10V
- Clemens
Does anyone of you have a spare center console at hand where he could check if these huge black plastic inserts around the shifter and where the OBD port is located can be removed?
Summer: 1996 855 R
Donor: 1995 854 10V
Donor: 1995 854 10V
- Has thanked: 1836 times
- Been thanked: 1709 times
Sorry, but no 850 console to hand. The V/S/C 70 console can be stripped down to individual components. You can remove the whole top section on those and swap in another if required. Even the rear section can be done. I had to do this a couple pf times on others cars where the arm rest mounts were broken off.
- 12 Replies
- 4282 Views
- 1500 Views
Last post by BlackThunder
