have a 96 -850 glt sedan with fabric seats and I want to change the interior seats with lether ones,I found a 850 -95 sedan T5 ?Are the seats interchangeble?
Can you tell me if they are similar inside Where I can find specification/dimensions for seats?
Thanks Adrian
850 seats specifications?
kenk
i dont believe they are.... they should mount up, but 96 they added side airbags... even if you just get the skins to cover over the seat (check ebay) you need ones from a 96 or newer to have the breakaway sewing in case you get into an accident.
Guest
The one I want to replace with are 95 but they have the side impact air bag Question is "kenk wrote:i dont believe they are.... they should mount up, but 96 they added side airbags... even if you just get the skins to cover over the seat (check ebay) you need ones from a 96 or newer to have the breakaway sewing in case you get into an accident.
Are they going to fit the same bolts on the flor?
How difficult is to do it myself?
My existent passanger seat do not have electric controls(is manual)Do I have the wires connectors ready in the floor for hook up controls for the replacement seat?
thenks for your time, it realy helps!!
Adrian
- Has thanked: 2660 times
- Been thanked: 1253 times
I think the only way to answer that is to get down in there and lookDo I have the wires connectors ready in the floor for hook up controls for the replacement seat?
