Now this is my question, even if you do not have the center speaker, does the Dobly surround system still work or is it pointless fitting the Dolby unit without the center dash speaker as that is what makes it ,Dolby surround sound'? The center speaker is fed from the back of the head unit separately, so not having it is that an issue?
His car has the behind dash amplifier but to fit the SC-900 I will have to see if we can fit the under seat amplifier as I don't know if the older amplifier can drive the SC-900 head unit.
Just when you think you have covered all the options for P80 head units, you find something different!
I have never seen the older behind dash amp unit so have no idea how it connects in. As the car has a SC-915/6 currently, I will have to remove it to see how it is connected and see if the head unit could be swapped for the SC-900 and it works with the old style amp, or if it has to be retrofitted with the newer system and amp.
So if anyone can school me on how the Dolby system works on these systems, I'd much appreciate it.
