'92 850 2.0 20V Intake Swirl Flap. Missing solenoid, do I lose a lot of power?
- koralski
- Year and Model: '92 850
- Been thanked: 7 times
Title says it all. I noticed that in my intake i have flaps that are vacuum operated. The car never had that solenoid. What are my options? Can I remove them somehow?
- Has thanked: 2203 times
Sorry, are you talking about the flaps in the air box? If so, that is just there for cold starts to warm the engine up more quickly when the engine is cold. Once the thermostat considers the car is warm enough it closes the thermostat and draws cold air from the front of the car.
These will fail with age and can jam on pulling air from the hot side reducing engine power. When that happens, owners will jam the flap to only draw cold air. They were only fitted to NA motors for some reason.
- Has thanked: 2857 times
- Been thanked: 1332 times
- Has thanked: 987 times
- Been thanked: 1075 times
I think the original post is talking about the variable intake manifold length. I don't know the details of the Volvo arrangement, but on my 2001 E320 Mercedes, it makes a lot of difference if the length change flap does not move as designed.
Find parts from a salvage car?
What variable length intake?
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Early 850 had variable intake(flaps in intake manifold).
I saw once a '96 with that set-up...probably with LH 3.2 Jetronic management since...in '96 they had both...M4.4 and Jetronic and in '97 only M4.4 was present.
@koralski...YES,you loose a lot of power if the system is not working properly...even in a 2.5 20v.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- koralski
I think we'll just change the intake. The system is complicated and the vacuum lines are gone, as well as the solenoid. I think the solenoid is NLA.
BTW, I will check the airbox. Thanks for that, i didn't know there was such thing as a thermostat for it
- koralski
Just talked to my dad, he did the airbox mod. He has another intake manifold so we'll change it. Thanks for the info guys. Helpful as always.
BTW, a little off-topic. Is there a way to directly support you Matt?
- misha
You will have the same results as leaving it as it is...because ecu is programmed to have variable intake.koralski wrote: 08 Apr 2025, 11:23 I think we'll just change the intake. The system is complicated and the vacuum lines are gone, as well as the solenoid. I think the solenoid is NLA.
You will need to tune the ecu to run the engine without it.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
You found it.koralski wrote: 08 Apr 2025, 11:39 BTW, a little off-topic. Is there a way to directly support you Matt?
Thanks for your donation, koralski!
- 203 Replies
- 10653 Views
Last post by volvolugnut
- 1288 Views
Last post by rodiram
- 295 Views
Last post by lrock
- 20 Replies
- 1624 Views
Last post by MoVolvos
- 1408 Views
Last post by SuperHerman
