Do you have any knowledge if removing this system would require a re-tune on the ECU? My car had that originally but sadly the solenoid is missing and I would like to remove it (for some performance gains).
My plan is to change the intake manifold with one that doesn't have that system.
Any Interest in a Thorough Volvo Variable Intake System write up?
- callahanoffroad
- Year and Model: 1995 850
- Has thanked: 16 times
- Been thanked: 52 times
The formal answer is yes. The ecu is programmed to include the variable intake length, similar to how VTEC Ecu programming in mid 90's Hondas is different than Non-Vtec motors.koralski wrote: ↑08 Apr 2025, 12:40 Do you have any knowledge if removing this system would require a re-tune on the ECU? My car had that originally but sadly the solenoid is missing and I would like to remove it (for some performance gains).
In the backyard mechanic, drinking homemade whiskey corner that I live in, the answer is: I wouldn't worry about it. Replace the intake with the new one and (provided that the intake ports match) you should be good to go.
As I'm sure i mentioned I locked my flaps into the "high rev" area and it worked just fine for many years.
- koralski
- Year and Model: '92 850
- Been thanked: 7 times
Thanks for the words of reassurance. I will change the manifold and report back if I feel anything.callahanoffroad wrote: ↑08 Apr 2025, 18:01The formal answer is yes. The ecu is programmed to include the variable intake length, similar to how VTEC Ecu programming in mid 90's Hondas is different than Non-Vtec motors.koralski wrote: ↑08 Apr 2025, 12:40 Do you have any knowledge if removing this system would require a re-tune on the ECU? My car had that originally but sadly the solenoid is missing and I would like to remove it (for some performance gains).
- Has thanked: 1497 times
- Been thanked: 3810 times
Nice to hear from you! I forgot you were in St Louis area, I dashed in on business a few months ago and picked up a nice red XC90 to replace Eugene, our old BMWcallahanoffroad wrote: ↑08 Apr 2025, 18:01The formal answer is yes. The ecu is programmed to include the variable intake length, similar to how VTEC Ecu programming in mid 90's Hondas is different than Non-Vtec motors.koralski wrote: ↑08 Apr 2025, 12:40 Do you have any knowledge if removing this system would require a re-tune on the ECU? My car had that originally but sadly the solenoid is missing and I would like to remove it (for some performance gains).
jmartin919
- Year and Model: S70 GLT SE 2000
- Has thanked: 94 times
- Been thanked: 39 times
Looking at that diagram and explanation of the engine mounts, what would be the most likely cause of feeling vibration when at idle in drive or reverse with foot on the brake? 2000 S70 with 100k miles. Upper torque mount and rear hydraulic mount replaced. End mount "seems" ok.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
- 2907 Views
Last post by Blockpartie
- 841 Views
