I wonder if the dead fan is preventing the AC from cycling on, it runs when the AC is turned on.
From NH I would scoot down 93 to N. Billerica and picknpull your own fan from Hollands salvage.
Have you checked voltage at the fan plug, should see constant 12v on the red wire, 5v or less on the small violet wire.
2007 Volvo XC70 - A/C Problems, Where to start...? Topic is solved
cmayo1
- Year and Model: 2007 XC70
- Has thanked: 51 times
- Been thanked: 9 times
Good to know! I'll have to try the voltage. I just assumed it wasn't working because of the deterioration from all the heat cycles it's gone through, so I haven't looked too deep. Hollands is only half an hour away, so it's worth the trip. I was thinking of trying Jean Guys because they have parts listed on car-part, but I feel like they're more expensive than most.
Thanks!
Thanks!
2007 Volvo XC70
free time ≠ money
free time ≠ money
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
I bought a new $550 fan, it still didn't work, the violet wire had green corrosion from physical damage near the plug, soldered a patch in and the old fan worked fine, sent the new fan back for refund.cmayo1 wrote: 24 Apr 2025, 15:58 Good to know! I'll have to try the voltage. I just assumed it wasn't working because of the deterioration from all the heat cycles it's gone through, so I haven't looked too deep. Hollands is only half an hour away, so it's worth the trip. I was thinking of trying Jean Guys because they have parts listed on car-part, but I feel like they're more expensive than most.
Thanks!
cmayo1
Ended up getting a radiator fan from Jean Guys in Pelham, NH for $75. They're a little bit more expensive and are expanding pretty quickly, but I'd rather pay to have it pre-pulled than risk having a stack of cars crush me. Maybe that's just me lol. Looks like it's a newer rendition of the fan because there's plenty more fan blades than the brittled one. Thing works, haven't given a full test yet. I believe this should fix the issue, because I got a car wash with the AC on (not really cold) and when water hit the engine, the AC got much colder. Will update tomorrow!
2007 Volvo XC70
free time ≠ money
free time ≠ money
- Been thanked: 4068 times
The fan is critical for AC operation as it pulls the heat from the condensor. It will chamge the low and high pressure AC readings drastically.
- 2068 Views
Last post by Fataqui
- 311 Views
Last post by tango_1000
- 56 Replies
- 12922 Views
Last post by jminish
- 20 Replies
- 1563 Views
Last post by yagger
- 2152 Views
