P2 V70 series wheel alignment specs
jrschwit
Year and Model: '01 V70 T5, '02 V70
Has thanked: 12 times
Been thanked: 8 times
Post by jrschwit »
I've searched here and elsewhere for accurate wheel alignment specs without success. Several references say they are contained in the owners manual, however, I cannot find them. Can anyone point me to an authoritative source for both front and rear?
New to me '04 V70 got a firm bump to the rear wheel resulting in slight bend to lower rear suspension arm. I've repaired that and reset alignment with a string to zero toe. Driving results are excellent and much improved. But I'd like to know exactly what the specs should be.
Also, I realize front camber is not designed from the factory to be adjustable except by means of the play inherent in the two strut mounting bolts. Probably has less than one degree of adjustability. Though it may not make much difference in tire wear or drivability, I'd like to know what the camber should be
DavidE7
Year and Model: 01-07 V70, S60, XC70
Has thanked: 53 times
Been thanked: 62 times
Post by DavidE7 »
The procedure is in VIDA for the V70. This is for XC70:
https://www.volvoxc.com/wp-content/uplo ... gnment.pdf
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 224,000 miles
2004 Nautic Blue XC70 2.5T 251,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 275,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 200,000 miles
P2 Volvos for every person in my family
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
jrschwit wrote: 24 Apr 2025, 12:46 I've searched here and elsewhere for accurate wheel alignment specs without success. Several references say they are contained in the owners manual, however, I cannot find them. Can anyone point me to an authoritative source for both front and rear?
Here are the front camber adjusters. Find a level spot and just stand a 3 foot level upright in the center of the rim and not touching the tires. Measure the upper and lower lips of the rim as long as they are true with no excessive curb rash. Best to be no more than 1/8" neg camber but 0 is best. Do not do positive camber. The same for front toe using a measuring tape no more than 1/8" toe in. These cars will drift slightly due to age of suspension if zero toe.
https://www.1aauto.com/2001-volvo-v70-s ... 001-569-64
https://www.fcpeuro.com/blog/at-home-al ... n-your-car
