Hey guys, here's my question. I'm getting code 222 for the tranny which means the s1 solenoid is bad. I'm going to get it replaced and figure I should might as well do the s2 solenoid. I have a couple of questions:
first, should I also change solenoid SL? second, how many hours, and how much should the labor run me?
thanks
transmission solenoid
volvo tech
you can change all three if you like.
if you have a:
850 or S70 5.5 hour
S80, S60 or V70 2001- 6.0 hours
if you look from the front to the back. on the tranmission right side is a black pan on the front. you have to get the pan off. you going to have to
drop the sub frame.
if you have a:
850 or S70 5.5 hour
drop the sub frame.
