car won't start. - 2009 - S60 Topic is solved
atillabjk
Year and Model: S60 - 2009
Has thanked: 7 times
Re: car won't start. - 2009 - S60
Post by atillabjk »
Hello friends;
Thank you very much for your help. However, I still could not start the car. I did everything you shared and described. However, the car does not start. Something like this came to my mind. My sincere friend also has a car exactly like mine, we bought it at the same time. Even the chassis number is very similar. Can I change the ECU or the PEM you mentioned to try and try to start it?
Because there seems to be no mechanical problem :(
Can I try something like this?
Has thanked: 1503 times
Been thanked: 3817 times
You need 3 bar fuel pressure for the car to run do I think this is finding your problem. Can you get the car in a quiet place so you can listen for the fuel pump on key turning in, without starting?
Vova585
Has thanked: 155 times
Been thanked: 142 times
Post by Vova585 »
I think you can swap PEM without issues. ECM will not work from one car to another. If you suspect that your problem is related to the lack of fuel- buy a bottle of "easy start" or "brake cleaner" and give a couple sprays into intake manifold prior to maf sensor or spray while cranking. If the car will start and run for second or two you have a lack of fuel and should concentrate on that area. However, if that does not change anything-save money and take it to professional diagnostic. Or see if you have reputable mobile mechanic that can come to your place with his scanner and scope and check everything.
atillabjk
Post by atillabjk »
Thank you for your answers.
Hello abscate; When I make the ignition in a quiet environment, I hear the sound of the fuel pump from the back seat. If that is what you are talking about.
But I don't know how many bars it is. Fuel comes out of the valve outlet on the engine side, less before the ignition, and more intensely after the ignition. As I said, I don't know how many bars it is, so it stayed like this.
Hello Vova585; As you mentioned, I will try PEM.
I will also buy an easy starter and try to start it as you described.
If it starts and the engine stops after 2-3 seconds, this means that it is giving less fuel. So is the fuel pump faulty? Or is it the fuel pressure sensor?
Thank you all for your interest.
sincerely
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
my $15 elm 327 code reader for smartphone can read your fuel pressure and pump duty cycle.
Vova585
Post by Vova585 »
Sir, I think it is time to throw the white flag and call for reinforcement. You are without car for more than month and we are not closer to find the solution. It will be cheaper to pay professional for diagnostics rather than buy parts and scanners at this time. I agree with jonesg that $15 sounds like a great option, but in much rather add some more money to pay professional for verified diagnostics.
It seems like you have fuel delivery, you mentioned you had spark, you reportable checkered the engine timming marks..so something is missing.. unless you dont need this car on the road and you want to play with it to fix yourself. Then start buying capable tools and we can try to help as much as possible following seeing clips of what was done and verified. However it is long and expensive road
Vova585
Post by Vova585 »
jonesg wrote: 17 Jun 2025, 14:53 my $15 elm 327 code reader for smartphone can read your fuel pressure and pump duty cycle.
Just checked the data from 1st page. He is using elm scanner as well. maybe Jonesg can help our friend with some tips how to navigate this scanner tool.
On the other note: how common is contrafact gasoline in Turkey? In the last effort I would possibly would remove the rear seat. Get access to the pump. Remove pump lock ring and gain access to the tank(clean around tank access and use compressed air to blow all dort away prior to opening). Evacuate all old gas and replace with 10L of fresh high quality gasoline. Remove the spark plugs and do the trick with oil into cylinders as suggested prior. Put new spark plugs and attempt to start.
atillabjk
Post by atillabjk »
Hello friends;
As you know, I was going to check if the PEM was faulty.
However, for the PEM located in several different places in my Volvo s60 2009 model vehicle. I looked under the back seat, it was not there. I looked under the fuel filter, it was not there. I looked at the top of the fuel tank, it was not there. Unfortunately, I could not find its location. Where else could it be. I want to check it this weekend and be sure.
I would like to express my gratitude in advance.
jonesg
Post by jonesg »
If this is a european diesel it will be located at the front of the car someplace.
atillabjk
Post by atillabjk »
Hi Jones;
I have an ELM327 device.
I use the scanmaster application. I sent the data there, in the previous post.
If there is another application, I would be happy if you shared it.
