Generic P80 AC clutch shim , bread clip, zip tie thread
AC Shim Fix: Are Zip Ties the New Bread Clips?
- patcal
- Has thanked: 99 times
- Been thanked: 10 times
My clutch on my 2004 S60 cycles on & off every 20-30 seconds. Can't seem to get 134r into it. Checked my gap was at .635mm. Way over. I'm going to try zip ties tomorrow.
Pat Callaghan Jr.
98 S70 GLT
98 S70 GLT
crasbe
- Year and Model: 02 S60, 98 V70 (EV)
- Has thanked: 33 times
- Been thanked: 82 times
I learned about this fix after having the refrigerant replaced in my 2002 Volvo S60 and the error that the compressor only cycled for a few times remained.
The P2 platform unfortunately has very little space to access the compressor and it seems like clutch is made a little bit different. One way or another, I couldn't even get in a zip tie behind the flower-shaped sping.
So I cut up a metal stap which had the right thickness and bent a small L-bracket out of it to slide behind the spring. That bracket then got bent up so it won't fall out and the gap was pretty much perfect at around 0.4mm.
In total I added three of the brackets and the gap was very consistent, so I didn't bother putting another three in.
Maybe that helps someone who struggles with zip ties when the gap isn't big enough
Check out my 3D Printed Parts for Volvo P2 and P80 on Printables
- rolsen11
- Year and Model: 00 V70, 04 S60R
- Has thanked: 57 times
- Been thanked: 58 times
Nice! That should work well for you. Thankfully I was able to stuff a few zip ties in mine a few weeks ago, though I cracked the screen on my phone in the process ): (it fell out of my hand and landed on a tiiiiny rock)
2000 V70 SE - Bought sight unseen in Cleveland, no longer my only car. Looks identical to my profile picture
2004 S60 R - M66 "Spaceball" manual transmission, Atacama "orange" interior, Titanium Gray metallic
- Been thanked: 4068 times
I’m reporting this case of Oetiker desecration to the appropriate authorities.
crasbe
If you only knew that that clamp was from a VW Bug axle boot kit tooabscate wrote: 16 Aug 2025, 03:53 I’m reporting this case of Oetiker desecration to the appropriate authorities.
Not even a Volvo part.
- 14 Replies
- 6851 Views
Last post by oragex
- 1613 Views
Last post by 99TurboBrick
- 1698 Views
Last post by Griffe
- 15 Replies
- 4201 Views
Last post by erikv11
- 10 Replies
- 1700 Views
Last post by dikidera
