Hello all!!
First post here. I hope I’m in the right forum section. I’ve just replaced my exhaust manifold and down pipe but I was told the pre-heat shield and heat shields are toast.
I believe I’ve got the correct replacement shields but I’m looking for information on hardware needed as well as a small tutorial on how to do this myself.
I hope that I can attach a photo of the shields I purchased. Also..is there a flexible metal hose liner too that’s needed…? Novice here…if we can keep it as simple as possible that would be great!!
Thank you all for any help…
Installing pre-heat and heat shield 1991 240 sedan
Flyingdutchman
- Year and Model: 1991 240 sedan
Flyingdutchman
Vova585!
Thank you for responding to this thread for me. I did see the heat shields quickly in the video and see that they are secured by a few nuts. When I get under the car I will know if the hardware is already present or will have to get some. Thank you for your help. Mike
- 448 Views
Last post by TheLoneAviator
- 538 Views
Last post by kahl
