04 XC70 crank no start conditon
pilsbury88
Year and Model: 2004 XC70
Re: 04 XC70 crank no start conditon
Post by pilsbury88 »
Posting my foolishness for those that may come looking in the future.
It just needed some gas. 🥲
So, the fuel pump gets power for about 1 second at key on, and then gets power again during cranking. I confirmed I had power during a crank cycle. Added 3 gallons of gas. And it fired up. I guess my fuel level was just too low for the pump to grab it.
Hopefully that wraps this one up for now. Now onto replacing rear subframe bushings, shocks, and springs. Thanks for the assistance guys 👍
Has thanked: 1500 times
Been thanked: 3812 times
You’re the first person here to ever run out of gas.
sincei ran out in the Kat
pilsbury88
abscate wrote: 16 Sep 2025, 04:10 You’re the first person here to ever run out of gas.
When replacing the fuel pump, the drivers side of the fuel tank under the float was filled to the brim. The passenger side did look low. After replacing the pump I did jack up the drivers side of the car to attempt to transfer some of the fuel over to the passenger side of the tank. I thought the pump would be able to pick it up. I thought wrong. 😆
