I'm trying to strip the rear end of the cams so I can get the locking tool onto it. I'm doing a comprehensive timing job.
I've got the vacuum pump and intake cam plug off no problem.
Both of the T30 torx bolts that hold the CPS rotors in place aren't moving. It's as though some jerk used loc-tite on them.
I did try pushing the ratchet both ways, no cigar, but just to ask it: these aren't reverse threaded, are they?
Is there a special technique here that I don't know about?
Anyone know where I can find a T30 ratchet bit built for taking MAXIMUM abuse? I've already had two snap on me.
2014 S60 2.5T AWD, cam position rotor bolts stuck?
- Has thanked: 987 times
- Been thanked: 1075 times
Have you tried using an impact wrench? It may shake the bolts loose.
Some quick heat on the screw head may loosen as well.
Use name brand, US made T30 bits.
- kcodyjr
- Year and Model: 2006 S60 2.5T AWD
- Has thanked: 17 times
- Been thanked: 23 times
No, I figured if I was able to break the bit with an average length 1/2" drive ratchet, a pneumatic impact wrench might rip things apart. Do you mean I should try a manual impact wrench, the kind you whack with a hammer?volvolugnut wrote: 29 Sep 2025, 13:56 Have you tried using an impact wrench? It may shake the bolts loose.
5 others that came and went
If you have the manual (hammer) impact give it a try. The hammer jolt and the tuning may be just what you need. This has worked for me on carb jet screws that were stuck.
- kcodyjr
For $30 on Amazon I'll give it a try.
Enough of my s***box fleet is operational that this one can wait for the right tool to ship.
Are you affirming my instinct that a pneumatic impact wrench would probably be a bad idea, or are you just saying I should try a small whack before I try a big one?
Try both, but the manual impact might work first.
The manual tool is handy anyway.
Having a fleet has it's advantages.
- 2221 Views
Last post by Roger_850T
- 1423 Views
Last post by Sannerdm
- 1308 Views
Last post by Nevada1906
- 744 Views
Last post by JBC2565
- 571 Views
Last post by oragex
