Can new PCV box be defective?
Jotunn77
Year and Model: 97 855t - 91 945t
Has thanked: 6 times
Been thanked: 4 times
Post by Jotunn77 »
Used an aftermarket kit that I assume came with the cheap stuff. Replaced the PCV the system with no issues. Could not believe the state old system, btw. Did a test drive and had oil spray for the dipstick tube. Not the result I expected. Took everything back off to check my work and found no issues. It blows smoke from the dipstick and inflates a glove from the oil cap in the classic fashion. I am gonna try the 5/8 heater hose mod since I’m in here and it looks fun. But I’m curious if anyone has had a PCV box fail right off the shelf? Is there a way to find a fault with the box off the car?
1997 855 T5 - 297k
1991 945T - 121k
Has thanked: 1850 times
Been thanked: 1712 times
Did you make sure the oil paths into the engine block are clear? The lower one in particular can block around the 90 degree corner. The only way to successfully clean it is to pull the oil pan and clean up from below.
Did you replace all the pipe work as well as the flame trap?
Sorry nearly forgot. The oil trap is a fairly simple device. It is just a series of baffles. If you can blow through it then it should work.
Has thanked: 292 times
Been thanked: 765 times
Make sure you didn't reverse the hook-ups for the two hoses to the top of the PCV box.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Jotunn77
Post by Jotunn77 »
Sorry, delayed reply. The hook ups are correct but I have not dropped the pan. As the tutorial mentioned, I blew into the oil return port and heard bubbling and assumed I’m good.
This was the PCV oil return on the old system and oddly crank case pressure was not an issue. I just did a compression test today with 150 across all cylinders. Should I be looking at the turbo? If so, I’m not sure where to start. Could it also be the ECU relearning and slowly adjusting?
1997 855 T5 - 297k
1991 945T - 121k
I don't see a clear reason why it would be the turbo.
Nothing for the ECU to "relearn" after PCV work, it's not that.
Most likely seems something not hooked up with but I haver no good ideas ...
'06 S60 R, 197k
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Compression test will tell you something and not telling you anything....leaving you to chase your own tail.
That said....if oil control rings are shot...compression will still be good but it will pouring oil into intake through pcv system.
Testing should be more intense...compression,leak down,dry & wet.
I had a car once which was pouring oil into intake...head was good,spark plugs nice & dry,no blowby.
After opening... the shop said that oil control rings were shot.
It was consuming 1l of oil per 400km...and exhaust was full of oil which transformed to grease at the end of the pipe.
Engine rebuilt was performed,head rebuilt(since it was off anyway,piston rings,seals....after that i got 100k km from that car wit ZERO oil consumption.
I sold it like that and it's still running strong.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Jotunn77
Post by Jotunn77 »
I am getting tired of chasing faults and it may be time to take it in. Thanks for all the advice. I’ll be sure to post the resolution later on.
1997 855 T5 - 297k
1991 945T - 121k
Jotunn77
Post by Jotunn77 »
Just a follow up. I did not take the car in and ultimately got things right. Here’s a quick rundown of work done to stop the crankcase pressure.
Another smoke down revealed vac leaks at PTC and the bottom end of the intake hose that goes into turbo inlet. The PTC rubber boot was no longer sealing. The intake tube was cracked and had a ripple where the band clamp goes that prevented it from sealing. There was also a leak at the vacuum tree.
I tried liquid gasket to get things to reseal but it was no good as even more smoke dumped from the faulty connections. The vac tree simply needed a new o ring.
To address the intake hose, I ordered an aftermarket one from Do88. Out of the box, the fitment was pretty bad for a stock car. Took a few emails to Do88 to get what I needed to mod the intake for stock tolerances. Frankly, It was a pain for the cost of it. The part is definitely for the modding crowd but there’s really no OE replacement options. In the end everything sealed up.
So with all the vacuum leaks addressed, the car finally passes the glove test.
1997 855 T5 - 297k
1991 945T - 121k
ZionXIX
Has thanked: 65 times
Been thanked: 194 times
Post by ZionXIX »
Jotunn77 wrote: 07 Feb 2026, 11:39
This was part of my hesitation in purchasing the do88 pipe. What mods were needed to get it to fit?
